Old 06-23-2016, 01:32 PM   #1
Greg2SS
Drives: 2012 Sliver 2SSRS L99 83red RS 305
Dry lifter, any advice?
I bought my 2012 SS a few months ago. They hadn't changed the oil before placing it on the lot, part of the deal was they would service the car when I bought it. Had it for a while before the appointment came up. I took it in, it did fine for about 2 months and now on startup only after it's been parked for a long time, over night or through a shift at work, it has what sounds like a dry lifter. Again, only at start up and only for a second. Has anyone else had this problem? Or can anyone just give me some information on this problem? What causes it, how to correct it. Thank you guys in advance.
Greg2SS is offline   Reply With Quote
Old 06-23-2016, 07:02 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Lots of people had the same faulty lifters.....search the forums here and you'll get educated on the issue....there's a TSB on the afm lifters. Welcome and good luck
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 06-23-2016, 08:51 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Got the AFM lifters replaced with an improved design, per the TSB and under warranty.
Rock-It Man is offline   Reply With Quote
Old 06-25-2016, 10:35 AM   #4
Greg2SS
Thanks guys. I'll look for the other threads.
Old 06-30-2016, 10:30 PM   #5
LIMA99
Skinny jeans are in ya'll
LIMA99's Avatar
Drives: 2015 Camaro 2SS w/ 3.91 gears.
Mine does it every day. Its normal for a little clatter for like a seconds as oil fills the lifter its gonna do this but it should go away. If it is constant or above a second I would suspect AFM lifter if u got an automatic like me.
LIMA99 is offline   Reply With Quote
Old 06-30-2016, 10:32 PM   #6
LIMA99
LIMA99's Avatar
These V8 Camaros have their own personalities. MY 2012 V6 WAS SILENT.
Old 07-01-2016, 07:58 PM   #7
Rock-It Man
After lifter replacement, I have NO clatter...not even for a second. The clatter is due to a faulty lifter design and is not acceptable.
Old 07-01-2016, 09:27 PM   #8
LIMA99
LIMA99's Avatar
Hmmm I have a 2015 Silverado does it too. Is this something should take in now to the dealership?
Seems to me the lifter is bleeding out its oil charge upon shutdown?
Old 07-07-2016, 10:23 AM   #9
Greg2SS
Mine doesn't do it every time I start it. Some mornings and some evenings, no matter the temperature, it doesn't do it. Only some times. For a week or two, it did it every time. Since it is out of warranty, what lifters would you guys recommend?
engine noise, lifters, oil
