Old 06-23-2016, 01:59 PM   #1
DrDJ
Drives: 2013 ZL1 White A6
Factory ZL1 battery life span
Anyone have experience with the factory battery needing replacement? Searched the forums but didn't see solid answers. If anyone knows what the expected lifespan of the stock battery is, and if any have had it fail sooner than that anticipated timeframe please post your experience. Thank you
DrDJ is offline   Reply With Quote
Old 06-23-2016, 02:02 PM   #2
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
My battery just went bad, almost 4 years and 58,000 miles in the desert.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 06-23-2016, 02:02 PM   #3
BeachBum
Drives: 2012 (ZL-1) #468
I Still Have The Factory Battery In "Baby" And It's Performing Well - It's over 4 Years Old Now And No Problems
BeachBum is offline   Reply With Quote
Old 06-23-2016, 07:26 PM   #4
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
If it is a daily driver, 7 or more years.
4 to 5 years if it is not a daily driver.
Dimitrim is offline   Reply With Quote
Old 06-23-2016, 08:29 PM   #5
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
The number of cranks, and if it sees winter, and if you ever refresh it are all determining factors.
ZMEnow is offline   Reply With Quote
Old 06-24-2016, 07:26 AM   #6
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
I don't know how Mississippi weather is on batteries, but the heat/humidity here in FL is a battery killer. I'll be happy to get 3 years out of mine.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 06-24-2016, 07:50 AM   #7
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
There have been several no start, dead battery threads. My 2014 1LE was about 1.5 years old, and out of the blue it was just completely dead one day. I normally keep my car on a battery tender, as I dont drive mine everyday. For a couple of days I didnt, and thats when it went dead. Took it to the dealer, and they had it for several days. They tested the battery and told me it was fine. They did however replace the software in the Body Control Module.
The car after that, stayed on 15 volts (the battery voltage meter) all the time. I had the dealer replace the battery. I think these cars have a fair amount of parasitic current draw with all of the electronics in them.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 06-24-2016, 08:42 AM   #8
HDRDTD
I proactively changed the batter in my 2013 with 28k miles when it was 3 1/2 years old.
I had been polishing the car for 5 hours while listening to the radio set to a low volume. I went to start the car about 1/2 hour later and it wouldn't turn over. Put it on the tender for an hour and it started right up. I decided then just to go ahead and change the battery.
Old 06-24-2016, 08:56 AM   #9
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
Long shot but could the battery be covered by warranty? or is it considered a wear item? Like clutch and etc
My 2014 doesn't get driven much. Maybe 1 or 2 times a month since I bought it, and Just recently the battery dies and loses charge instantly. Car only has 4700 miles on it
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 06-24-2016, 11:24 AM   #10
Sven59
HAMMER PILOT
Sven59's Avatar
Maybe under the 36,000 but I would say only if the battery was defective.
Old 06-24-2016, 12:49 PM   #11
winterboy8
winterboy8's Avatar
They're normally pro-rated, even while under warranty.
Old 06-24-2016, 08:58 PM   #12
jonm38
Drives: 2016 Siliverado LT. Camaro SS
My battery lasted 15,000 miles, 2013 ZL1
Just Cruising!
USN - 1990 - 1994
2010 Camaro 2SS Red Jewel
jonm38 is offline   Reply With Quote
Old 06-24-2016, 09:51 PM   #13
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Bickle beast that they are, it really depends on the conditions the battery is kept in (excessive heat or cold), and how the battery is maintained (driven sufficient distance daily, or on a Tender). I'd say a good average is 3-5 years. Test it periodically, and as long as it's maintaining a solid charge after sitting overnight (12.5-12.8 volts), it should be fine. They can go bad quickly though....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-24-2016, 11:03 PM   #14
mpd659
mpd659's Avatar
Drives: 2014 Chevrolet Camaro SS
I have a 2014 Camaro SS with 18,000 miles. The hand held battery tester at Chevy dealership said it was bad. GM will replace it under warranty. But, they have to hook it up to this large tester. It runs about 80 or 90 minutes. It charges the battery, puts a load on the battery, etc and that came back in specs. So, GM wouldn't warranty the battery. I live in Florida and everyone says you get about 2 to 3 years max out of a battery in Florida. I'm going to have them test it one more time just before my warranty expires.
mpd659 is offline   Reply With Quote
