Old 06-23-2016, 09:21 PM   #1
songsj
Drives: 2015 2SS/RS Summit White
Auto Tranny Temp
I have a 2015 2SS/RS L99. Auto transmission temp runs a little over 180 by the console gauges on hot days in traffic. Is this normal? I really hate anything over 180, however I suppose one can't be too sure how accurate those gauges are either. Thoughts? Car has 1700 miles on it.
songsj is offline   Reply With Quote
Old 06-23-2016, 09:35 PM   #2
The_Driver
Banned
Drives: 2015 Camaro 1LS M6
Sounds normal to me. Can always upgrade to an aftermarket cooler to reduce temps even more.
The_Driver is offline   Reply With Quote
Old 06-23-2016, 10:35 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Sounds normal to me also.
Rock-It Man is offline   Reply With Quote
Old 06-23-2016, 11:06 PM   #4
SS/RS2010
SS/RS2010's Avatar
Drives: 2010 2SS/RS
Hot day, stop and go traffic, yeah, sounds about right.
SS/RS2010 is offline   Reply With Quote
Old 06-24-2016, 02:15 AM   #5
songsj
Thanks, guess I'm not going to worry about it as long as it doesn't go much higher.
Old 06-24-2016, 06:04 AM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
PM SoChrisB about a trans cooler. I met him over the weekend and he was talking about how well his trans cooler worked and kept his temps at or below 180 even at the track with a supercharged L99. It was quite impressive.
Check out my build thread
Old 06-24-2016, 11:17 AM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Your fine.....with my mods gears and stout trans tune your running right where I am.
rontammy0 is offline   Reply With Quote
Old 06-24-2016, 11:38 AM   #8
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Use Hammdo's strategy and buy the better oil pan
http://www.camaro5.com/forums/showth...04#post9168004
Not only will your trans be much cooler in these hot summers but you'll be able to change your fluid whenever you wanted.
Dmpsix is offline   Reply With Quote
Old 06-24-2016, 02:21 PM   #9
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I find mine runs hot too. It is only ever at 180 on the highway. In stop and go it will get up to about 215 or 220 which I don't like personally but it seems to be what it does. I would say it is about halfway between the center mark (180) and the first white line (250) so thats how I guess it is 215 or so.
It has never gone higher than that yet mind you. I think the trans cooler on these cars is more of a heater in fact. My coolant will hit 220 at times so its no wonder the trans is up near that too.
I asked my tuner about this a while back and he said its not a problem. I know the Dexron VI can handle higher temps than the old stuff did.
qcman is offline   Reply With Quote
Old 06-24-2016, 02:29 PM   #10
rontammy0
Is your gauge in Celsius or Farenheit? Mine in Celsius and sits right at 80 on the gauge.
Old 06-24-2016, 02:41 PM   #11
qcman
qcman's Avatar
No mine is in F as it was a U.S market car brought back to Canada but the 180 would be about 82C I would think. Its the same gauge and scale just with different numbers...
It bugs me that my trans seems to run hotter than everyone elses around here or so it seems. It warms up higher pretty quick once there is a fair bit of shifting in slow traffic. I often wondered if it had anything to do with the tune but the truth is I never payed attention to it until I noticed it up a bit higher one day. So I really can't say for sure. The next time its at the dealer I was going to get them to verify the fluid level is where it should be.
Old 06-24-2016, 02:52 PM   #12
rontammy0
I think your right about getting it checked....imo it should be the same as everyone else.
Old 06-24-2016, 03:32 PM   #13
qcman
qcman's Avatar
Thx yeah I just don't feel good about it. I'm not sure what else would explain it other than fluid level? The tune shouldn't be an issue as the firm shifts are easier on the clutches as there is less slip which would cause more heat I would think. I'm back on the original (most aggressive) tune BTW. Although it was the same on the softer tunes too so that isn't a factor at least.
I wish this car had a damned dipstick for the trans. How lame is that?
Old 06-25-2016, 09:55 AM   #14
qcman
qcman's Avatar
I stopped by my dealer yesterday but the trans guy had left for the day. So the SA said he would ask him about my temps and call me back on Monday. He assured me the temps I'm seeing won't hurt anything in the mean time though. He says his truck will sometimes hit 250 F or 120C but that seems really high to me. He asked me if I ever saw a code or anything and I said no and that the trans works just fine but runs a bit too warm doing it.
I suspect they will tell me its normal even though we think it might not be here. If they want to check it I was thinking I may want to return the car to the all stock tune? Any thoughts on that one?
