![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 camaro ss Join Date: Jun 2010
Looking for a new motor
I was thinking about a 416. Will be with a slptvs2300. Or should just forge stock 376?
I would stay with a 376 configuration. It's not what I did but it's what I will do next time. It will be happier at high RPM and easier to make boost on with the 2300. It will make boost on a 416 or 427 but it takes more effort.
Not sure yet but I might go tt but it won't be for a while. Right now the Tvs is what I'm stuck with. So most people build 416 for all motor?
![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
I dunno, I am selling the LS3 long block out of my 2012 with 13k on it. Putting in an ERL Superdeck 6. The TVS is a tiny blower for anything much larger than 376. I am putting a F1A on the 427 and thats still not enough blower.
One Slow Automatic
Drives: 2017 GS 2010 CAMARO SS Join Date: Mar 2010
forge the 376!
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
#6 |
![]() ![]() Drives: camaro ss\rs Join Date: Jun 2014
why not buying a b15 lsx?
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
#7 |
Drives: Camaro Justice Join Date: Jun 2007
How crazy do you want to go?
RWHP??? |
#8 |
I would like to be pretty crazy but can't at the moment. Maybe 900whp+ through the th400. Also a thought that crossed my mind is sell the SLP and stay all motor until I can afford tt kit or procharger
#9 |
#10 |
![]() Drives: 2010 2SS Join Date: Nov 2013
Here is my story, learn from it....lol
I had a forged 376 with my TVS, made 736rw with a 3.2 pulley and still had a 3.0 pulley to use. Friend bought a ERL 427 and ended up changing his mind. So I bought it, bought bigger heads, new cam ect. Obviously not a cheap build. I put the 3.0 pulley on it, put a ported snout on the blower, Made a 5" air intake for it, added a water/Ice tank. I made 761rw....Didnt even pick up 30hp. The blower can not keep up. I made 17psi and carried through the rpm range with the 376. On this engine, it starts at 17 and drops to 13 by the end of the pull. I knew the blower would really limit the car, but didnt realize it would be that much. After buying this ERL engine and after talking with more people, its not worth it. They have issues. I would highly recommend looking at other options. |
#11 |
Thank you sir. This is why I'm thinking of selling the blower to help out with the 416 then once I'm settled get a procharger or agp kit and turn up the boost
#12 |
![]() ![]() Drives: T Join Date: Mar 2015
Flip the tvs add some more cash go turbo, ecs, or whipple. I think all 3 of those options will produce 900 or more.
#13 |
Too much is never enough!
Imo 376 is fine for a turbo build. But lots of people go bigger.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 2010 SS Camaro Join Date: Jul 2009
417 and put the AGP kit on it and make 1,000hp easy.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
