Old 06-24-2016, 03:54 PM   #1
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Rocker Failure
Well was driving the car today and heard a horrendous noise coming from under the hood. I pulled off immediately and stopped in a plaza. I called AAA and had the car towed to Vengeance immediately. About 45 min later they had it fixed. A GM rocker failed, luckily I had the heads upgraded and that prevented a worse problem. They also replaced the pushrod too. Just be in the lookout, 1200 miles on my car.
Schlok is offline   Reply With Quote
Old 06-24-2016, 04:10 PM   #2
68camaroz28
68camaroz28's Avatar
Drives: 68 Z28, 69 Z28, 2015 Z28
What do you mean "luckily I had the heads upgraded" and how did that prevent worse?
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro
http://www.camaros.net/forums/showthread.php?t=182584
68camaroz28 is offline   Reply With Quote
Old 06-24-2016, 04:19 PM   #3
Schlok
Schlok's Avatar
First, unrelated though, the valve guides were redone, thus there was little chance it was the dreaded dropped valve problem. Related to this, the trunion upgrade helped alleviate the rocker from scattering needle bearings around the valve train and into the cylinders.
Old 06-24-2016, 04:59 PM   #4
CFD
Drives: 2SS/RS L99 BLACK
So if I'm reading this correctly it's a trunion upgrade failure not a GM rocker failure. I'm quite familiar with it.
CFD is offline   Reply With Quote
Old 06-24-2016, 06:11 PM   #5
Schlok
Schlok's Avatar
I did some more reading about this upgrade after and have seen this "happens." When they first told me what was wrong they said "the rocker is broken" which to me meant physical failure. It does sound like that is what actually happened, a trunion failure.
Old 06-24-2016, 06:25 PM   #6
JusticePete
Drives: Camaro Justice
Old 06-24-2016, 09:35 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it is noted by many tuners that rockers with the trunion upgrade fail where the stockers seem to live no matter what. I hope there isn't any collateral damage.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-24-2016, 10:02 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Yup, I had a trunnion failure on my 07 Z06, and never had any issues with the rockers prior to the "upgrade". Found the needle bearings in my oil before I noted any issues with the valve train (strange, but guess I just happened to change the oil within a few miles of the failure). Not the end of the world, since the needle bearings are unlikely to find their way anywhere but in the oil pan, but not something any of us want to have happen. I'll be looking into the bronze bushings when it comes time for an upgrade.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-25-2016, 02:04 AM   #9
chip4
chip4's Avatar
Drives: 2015 Z/28 Silver #713
So what exactly failed in the “Trunion Upgrade”? Was it not secured correctly? Installation error? Was there a crack or physical defect? Who is the manufacturer of this Trunion? Any pictures?
chip4 is offline   Reply With Quote
Old 06-25-2016, 04:01 AM   #10
68camaroz28
X2 and still trying to understand why without the change/upgrade it could have been worse. Seems the issue is the upgrade?
Glad all is OK but wow!
Old 06-25-2016, 07:30 AM   #11
Rich J
Drives: 2018 ZL1 Manual
I did a trunion upgrade with the Comp Cams kit on my 09 CTS-V. You have to be careful with the snap rings. Improvising without the right snap ring pliers can overstress the ring and cause a failure.
Rich J is offline   Reply With Quote
Old 06-25-2016, 12:59 PM   #12
Schlok
Schlok's Avatar
No pictures, Vengeance had it back together in a jiffy. I have a comp cams upgrade kit. One of those things I piled on to my build, figured it was a smart move at the time, perhaps not....I had WCCH do their stage 2 on my factory heads...
Old 06-25-2016, 01:09 PM   #13
CFD
I had two rocker failures then went to the Comp trunion upgrade and had many failures. Scrapped it all and went LLSR with T&D rockers, so far so good.
Old 06-25-2016, 08:28 PM   #14
Olddudesrule
Resident nomad
Sorry, no pics. In my case, happened about four years ago. When I pulled the rocker, it had cracked just behind the slip ring on one side, allowing the needle bearings to work their way out. I knew it hadn't happened more than a few miles before, because the rocker would have most likely completely broke very soon after. If you search for trunnion rocker upgrade failures, I've seen several pics of just the same failure I had. I'm not saying the "upgrade" isn't just that, only pointing out that I had a failure.....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
