Old 06-25-2016, 12:33 PM   #1
Dhaliwal559
Dhaliwal559's Avatar
Drives: 2015 Chevy Camaro 1LT/RS
Finally installed all my mods. Went from stock to bolt on in 1 night lol
Hey finally had some time to install my parts. I haven't recieved my tune/autocal/e85 from will. Will I be able to run with all these parts below for a week or so until tune comes in? Or will it run rough cause the computer won't know?
My current mods now are
My Mods
JacFab intake spacer
JacFab 80MM ported intake manifold
RotoFab intake
Vitesse throttle controller
Overkill 80mM throttle body
Waiting on tune and e85
Have a good day!
Dhaliwal559 is offline   Reply With Quote
Old 06-25-2016, 01:20 PM   #2
Machinehead
Drives: 2012 LS
Nice! Time for some exhaust mods ours sounds like a civic
Machinehead is offline   Reply With Quote
Old 06-25-2016, 01:31 PM   #3
Dhaliwal559
I'm running a muffler delete with quad tips, sounds decent, and finally installed the famous catch can everyone says you should buy haha
Have a good day!
Old 06-25-2016, 02:25 PM   #4
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
You should be fine running it without the tune.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 06-25-2016, 02:58 PM   #5
Dhaliwal559
Update, my tune, e85, and prosport gauges are here. Time for some play time.
Have a good day!
Old 06-25-2016, 03:01 PM   #6
Dhaliwal559
Christmas came early
Have a good day!
Old 06-25-2016, 03:37 PM   #7
camrytt
camrytt's Avatar
Drives: 2017 ZL1 A10
How much is the 80mm ported manifold going for
Current: 2017 ZL1 A10
previous: 2019 1SS A10
previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears.
Past: '12 LFX, full bolt ons + E85, 302hp/267tq
camrytt is offline   Reply With Quote
Old 06-25-2016, 03:38 PM   #8
Dhaliwal559
I paid 250$ I believe.
Have a good day!
Old 06-25-2016, 04:18 PM   #9
camrytt
camrytt's Avatar
I wonder if that would help fix mine throwing me codes every day
Old 06-25-2016, 06:41 PM   #10
onelraad
Drives: 2016 1LT Camaro V6 A8
Congratulations, how well you got satisified with these? Do they work like they claim for, its supposed to gain like 50 rear wheel horsepower, do you notice that? And am planing to have the same mods! Btw did they throw any codes?!
onelraad is offline   Reply With Quote
Old 06-25-2016, 07:03 PM   #11
Dhaliwal559
I'm extremely satisfied.. And I haven't even tuned or e85. Imagine with those, it'll be a bigger difference.
And as far as codes go, I haven't go any, running smooth, maybe a little bit of stuttering, but that's no biggie, computer is adjusting to the new mods.
And camrytt- get a code reader and see what's going on
Have a good day!
Old 06-25-2016, 07:03 PM   #12
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Changing intake manifolds will not stop you from throwing codes... What kind of codes are being thrown?
Jason@JacFab is offline   Reply With Quote
Old 06-25-2016, 07:13 PM   #13
dreyesforeal
dreyesforeal's Avatar
Drives: 2013 camaro LFX
Watching this since I'm doing the same except Ima go cai with mrtv2 and resonated x pipe
dreyesforeal is offline   Reply With Quote
Old 06-25-2016, 07:23 PM   #14
camrytt
camrytt's Avatar
Reduced engine power, service stabilitrack. Ever since tuning the 80mm tb. Back to tuner on Wednesday then scrapping it they can't get it to work right, back to vmax
bolt on, camaro, overkill
