06-27-2016, 12:17 PM | #1 |
Steve from Canada.
Drives: 2010 SW SS/RS with Inferno package. Join Date: Mar 2009
1LE vs SS?
My son is looking for a newer Camaro in Alberta and found a 2015 1LE. What is the difference between it and a SS?
Thanks.
06-27-2016, 12:42 PM | #2 | |
Drives: 1le Join Date: Nov 2015
But a quick google search produced this. The 1LE also features exclusive, monotube rear dampers instead of the twin-tube dampers on SS models. The new hardware allowed engineers to tune the 1LE suspension to focus on optimal body-motion control while preserving much of the ride quality and wheel-motion control of the Camaro SS. Other changes to optimize the 1LE for track-day use include: - Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for improved body control - Higher-capacity rear-axle half shafts to cope with increased levels of traction - Strut tower brace for improved steering feel and response - ZL1-based 20 x 10-inch front and 20 x 11-inch aluminum wheels - 285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear (identical to the front tires for ZL1) - ZL1 wheel bearings, toe links and rear shock mounts for improved on-track performance - ZL1 high-capacity fuel pump and additional fuel pickups for improved fuel delivery during high-cornering - ZL1 spoiler - Suede Flat bottom steering wheel. - Suede short shifter from ZL1 - "Camaro" labeled Red Brembo 4-piston Calipers - 3.91 final drive. along with closer gear ratios - Wrapped hood __________________ |
06-27-2016, 01:28 PM | #3 |
WILD CANADIAN HEARTBEAT
Drives: 2014 2SS 1LE RS, 2014 ZL1& 2024 ZL1 Join Date: Sep 2014
And you can only get the 1LE in a manual. No autos.
700/633 91Octane Street Tune=750/670 VP109 Race Tune TVS2300 Heartbeat SC,ADM Dual Fuel Pumps/ Module, BRM lowered 1", performance rotors, hawks pads, SS Braided lines, GT-14cam, 78mm pulley, AR LT Headers, Cat Deletes, Borla S catback, tinted, 1/LE emblems, 65lb Injectors, Elite catch can,dual valve springs, titanium retainers, super conductor wires and insulators, Robo Fab CAI, Oversize intercooler reservoir, Oracle ghost side markers, Black out Bowties & SS,ZL1 splash guards, Michelin PSS. Built and tuned by Davenport Motorsports (WILD1LE)
06-27-2016, 01:31 PM | #4 |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
100% more smiles per mile.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
