Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 06-29-2016, 08:41 PM   #1
mercraus
It doesn't mean anything
Drives: 2011 Camaro LS
SOLD - NyTrex V6 Nitrous Kit - Plus Extras - $600 Shipped
SOLD
Selling my NyTrex V6 System.
Never installed.
Extra's:
Remote Bottle Opener
Blow-Down Kit
PLX AFR Sensor
(AFR Sensor is used, everything else was never installed and still new)
Price is $600 shipped.
Here are the pictures from when I got it.
http://www.camaro5.com/forums/showth...68#post6720068
This is a site that showed the kit and how easy it is to install:
http://www.superchevy.com/how-to/eng...t-nitrous-kit/
Description from Summit Racing
These DEI Ny-Trex Triple-Threat EFI and Plate wet nitrous oxide systems combine all three valve functions--nitrous, fuel, and purge--in one easy-to-install component. The Triple-Threat valve features a billet aluminum machined body with three integral solenoid valves. The systems use a T-Rex nozzle with a true blend spray bowl that delivers a swirl cone plume at a 110 degree angle to the center of the throttle body for an even blend.
The systems also include:
* 10 lb. black powdercoated nitrous bottle with brackets
* Liquid-filled bottle pressure gauge, 0-1,500 psi
* Chrome 660 high-flow bottle valve with gauge port
* 15 A wide-open throttle activation switch
* Braided stainless steel nitrous and fuel pressure feed lines
* Dual taper jet kit
* Adjustable HP jetting
* T-Rex Nozzle and adapter up to 250/300+HP
* Purge valve kit
* Fuel pressure safety switch, preset at 33 psi
* Electrical wiring, connectors, relays, and switches
* Mounting brackets and hardware
Hmmmm..... I should probably get a fancy sig
mercraus is offline   Reply With Quote
Old 07-01-2016, 01:41 AM   #2
Dhaliwal559
Dhaliwal559's Avatar
Drives: 2015 Chevy Camaro 1LT/RS
Still have it?
Have a good day!
Dhaliwal559 is offline   Reply With Quote
Old 07-01-2016, 10:31 AM   #3
mercraus
Originally Posted by Dhaliwal559 View Post
Still have it?
Yes
Old 07-01-2016, 12:17 PM   #4
Dhaliwal559
Got any videos of it in action?
Have a good day!
Old 07-01-2016, 12:18 PM   #5
mercraus
Never installed it.
Everything is still sitting in the box.
There are some other forum members that got the same system though, so there may be some videos posted.
Old 07-01-2016, 12:23 PM   #6
Dhaliwal559
Why are you selling? Just wondering
Have a good day!
Old 07-01-2016, 12:25 PM   #7
mercraus
Never got around to installing it, and actually sold the Camaro.
Don't have a car to put it in anymore!
Old 07-01-2016, 12:27 PM   #8
Dhaliwal559
Haha and it'll fit the 15 v6 RS?
Have a good day!
Old 07-01-2016, 12:36 PM   #9
mercraus
Not sure to be honest.
I got it before the 15 models came out.
Though I'd think it would fit any Gen5 V6
Old 07-01-2016, 12:57 PM   #10
Dhaliwal559
And does it include everything that needs it to work? Like its a full kit? No other purchases I need to make? Just plug and play right?
Have a good day!
Old 07-01-2016, 01:04 PM   #11
mercraus
Pretty much.
The only thing it doesn't have is a window switch (didn't come with the kit)
You don't technically need one. Just control the spray manually.
Most people use a window switch or progressive controller though cuz it makes operation simpler. And window switches aren't that expensive. (<$50 on Summit Racing)
Old 07-17-2016, 01:33 PM   #12
mercraus
Bump
Old 07-30-2016, 03:47 PM   #13
mercraus
Price is now $800 shipped
Old 08-09-2016, 05:40 PM   #14
mercraus
Bump
nitro, nitrous, nos, nytrex
