06-30-2016, 11:06 AM | #1 |
Drives: 1968 Bronco,2001 Fatboy,2010 SS Join Date: Jan 2010
Catch can install with oem connectors.
Hello all,
So I am here installing my catch can. I didn't buy one with a bracket, but hell, it is easy enough to make your own. I like working with aluminum, so I have some scrap aound the house garage. I decided to mount mine off of the radiator bracket, for ease of cleaning. Mine does not have a valve at the bottom. So, I took a piece of flat stock aluminum, put it in a vise and bent two 90 degree bends in it. Next I drilled two holes using the catch can bracket as a template. Once that was done I took off the engine cover and found the little U shaped hose from the engine to the intake. This is were I have the question, why doesn't anyone reuse the factory connections on this hose? It would seem perfect to reuse. The plastic is thick enough to make a connection to and use a hose clamp as insurance. Anyway, I reused them here are some pictures, maybe it will give others an idea. See ya, Bill
06-30-2016, 11:08 AM | #2 |
I forgot I have not uploaded a current picture of my car
Hope you like it, I know I do.
