Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 06-30-2016, 11:02 PM   #1
chase@ridetech
Drives: 09 GMC Yukon Denali
New Ridetech StreetGrip Kit for the 1st Gen
We have developed a new suspension package for the 1st Gen cars. The new StreetGrip kit provides the necessities to get your Camaro up to date.
-Easy to install - direct replacement for factory suspension - no other modifications necessary
-RADICAL improvement to ride quality and handling performance
-Composite rear leaf springs offer linear spring rate and saves 70lbs of unsprung weight!
-Vehicle-specific dual-rate front coilsprings offer the best of both worlds...ride quality AND crisp handling
-Delrin front control arm bushings eliminate unwanted movement and stiction in front suspension
-Tall balljoints dramatically improve OEM camber curve to give your car a much more stable feel through the corners
-Larger front swaybar minimizes unwanted body roll through the corners
-Delrin swaybar bushings eliminate unwanted movement and stiction in the swaybar to improve ride quality and handling performance
-Vehicle-specific RideTech HQ series rebound adjustable shocks offer the ultimate in ride quality and handling performance
chase@ridetech is offline   Reply With Quote
Old 06-30-2016, 11:03 PM   #2
chase@ridetech
Here is an overview of what The StreetGrip entails:
Old 06-30-2016, 11:06 PM   #3
chase@ridetech
Old 06-30-2016, 11:09 PM   #4
chase@ridetech
Here is a Link to the StreetGrip product Line:
http://www.ridetech.com/store/ridete...ip-system.html
Here is a link to the Full Ridetech 1st Gen product line:
http://www.ridetech.com/store/muscle...hash=V264.V328
Old 07-16-2016, 01:28 PM   #5
Travis104
Drives: 2014 ZL1
Does this kit lower the car at all? I have been looking at the hotchkis tvs kit that lowers 3 inches.
Travis104 is offline   Reply With Quote
Old 08-01-2016, 04:19 PM   #6
chase@ridetech
Travis,
It does lower the car, what year is your car? I can provide a picture to show the new height.
Old 08-01-2016, 04:28 PM   #7
chase@ridetech
Here is our 1969 with the complete StreetGrip kit installed
Old 08-01-2016, 04:29 PM   #8
chase@ridetech
Here is the 67-68 Body style with the complete StreetGrip installed including our additional 1 inch lowering kit.
Old 08-10-2016, 09:14 PM   #9
Travis104
Drives: 2014 ZL1
This kit looks good. Would you be able to add tubular upper and lower control arms to this kit instead of just getting bushings for the stock control arms, and how would your tru turn kit with drop spindles work with these springs?
Old 09-01-2016, 09:01 AM   #10
chase@ridetech
This particular kit is designed to use stock control arms, but I can put together a kit that uses the Street Grip rear and the then we can use our tubular arms and dropped spindles on the front with the tru-turn but would then go to our coilovers instead of the spring and shock separate.
