Old 07-07-2016, 11:51 AM   #1
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
2012 ZL1 Exhaust on a 2011 1SS
Does anyone know if I can swamp out my current stock exhaust for a 2012 stock Exhaust and still pass smog here in California?
Tapia5Gen is offline   Reply With Quote
Old 07-07-2016, 11:59 AM   #2
thegreatwhite
Drives: 2014 SS
if you put an exhaust system on your car that is completely the same as a completely stock 2012 SS then theres no reason it shouldnt pass smog in any state.
thegreatwhite is offline   Reply With Quote
Old 07-07-2016, 12:00 PM   #3
thegreatwhite
Drives: 2014 SS
but california will find a way to fine you so watch out
Old 07-07-2016, 12:12 PM   #4
Spec
Drives: 2010 Camaro 1SS LS3
Shorties - OK
Long Tubes - NOT OK, you will not pass because you have to remove the stock cats and that is a no-no in CA. You will fail the visual inspection.
If you add shorties, you don't have to touch the cats, and most shorties are CARB legal, you'll be fine.
As for the catback, you can do whatever you want after the cats - even go straight pipe. Should pass smog as long as you're not popping codes.
Spec is offline   Reply With Quote
Old 07-07-2016, 02:07 PM   #5
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
thank you TheGreatWhite, and Spec for that info. yeah the ZL1 is coming off my brothers 2012 ZL1.
Old 07-07-2016, 02:08 PM   #6
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
*ZL1 Exhaust system
Old 07-07-2016, 04:14 PM   #7
thegreatwhite
Drives: 2014 SS
the stock ZL1 pipes an cats should be legal. if it were my car i would find out which high-flow cats were CA legal cause a boosted car can have big power benefits to no or high flow cats. i think solo and or JBA make CA legal high flow cats
Old 07-07-2016, 04:31 PM   #8
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
I didn't not know that, thanks TheGreatWhite! time to do some research.
Old 07-07-2016, 04:44 PM   #9
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Just a heads up guys, JBA and Solo do NOT have high flow cats that are CA legal. JBA and ARH have shorty headers that are CA legal but no high flow cats.
Thank you,
Ricardo
Sales@Phastek is offline   Reply With Quote
Old 07-07-2016, 04:52 PM   #10
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
Thank you,
Ricardo
what would you recommend?
Old 07-08-2016, 05:54 AM   #11
DOC52
THE U
DOC52's Avatar
Drives: Camaro 1SS/RS
If you want to stay legal just do the cat-back. If you want headers, smog then put longtubes on after. Shorties do gain a little hp, but for the money and install you're going to end up wishing you did longtube headers, unless you're planning to turbo your car down the road.
DOC52 is offline   Reply With Quote
Old 07-08-2016, 09:05 AM   #12
Spec
Shorties net about the same as long tubes when you change out the cats. With Long Tubes, you either have to go catless straight pipe or hfc's. The cats is where 90 percent of the restriction is.
When you go shorties and don't do cats, the gain is minimal for sure. When you do shorties and hfc's, you're up there with lt's...
Old 07-11-2016, 12:25 AM   #13
Tapia5Gen
Tapia5Gen's Avatar
Drives: 5th Gen SS
Wow! man this is all good info. i am finally getting around to adding mods to my car. i am looking into adding the ZL1 front and rear bumper along with the rockers.
2011 ss, zl1
