![]() Drives: 2013 Camaro SS/RS Blue Ray Metallic Join Date: Aug 2013
LED Sequential Tail Lights
I have a 2013 Camaro SS and I am looking for smoked or black sequential LED tail lights. I found some on EBAY from epartsgogo but the connectors don't match up. Unfortunately they do not provide install instructions either. Has anyone used these or know of any LED tail lights in smoke or black that will work? I do not like the ones with the arrow!
![]() ![]() ![]() Drives: 2011 RS Join Date: Apr 2011
Check out SWEEPLITE.com if you want to keep the OEM look. I have chrome,clear lenses from EBAY. I've had these for years.
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I like these, but man they're pricey for just tail lights;
![]() http://www.carid.com/2010-chevy-cama...-75120471.html |
I've had the Technostalgia taillights for a few years with no issues. You might want to look in the "Lighting and Cosmetics" section as there are many threads regarding this.
#5 | |
We need more variety! A pic from from a few years back before the bulbs became a problem... |
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS Join Date: Apr 2013
1) I thought you need to normally install the afterburner yourself. 2) Why are these lamps shown with a white bezel in every photo regardless of the car's color? The bezel should not be part of the lamp. |
#7 |
So looking around a bit more, for some reason, CARiD carries pre-installed afterburner rings on tail lamps and markets these as coming from Oracle, even though Oracle's own site seems to only list the do-it-yourself kit (costs about $200.)
I found that they also offer these plasma rings which I think match the halo headlights on our cars a lot better: http://www.carid.com/oracle-lighting...-7192-053.html The only thing that turns me off is: 1) Not clearly designated as matching the RS package. I've seen some listing where they say the lamps specifically aren't for RS, but this listing says nothing. 2) It says these come with a "clear" lens whatever that means. I'm assuming there's no possible way the lamps aren't tinted red or that would be illegal, right? |
#8 |
My lenses are clear, but the lights are red. Illegal, depends on where you live. Did you check out SWEEPlite.com?
#9 | |
![]() But 500 plus tho...
#10 |
Considering I have my stock lamps sitting in a box. yeah. I rather just get the $200 afterburner kit and pay a shop $100 or less to install them. The round afterburners are apparently way easier to install, but I don't feel comfortable cutting the lenses.
#11 | |
El Duderino
but looks like a possibility
#12 |
I would just like to find the rapid fire option but not sure what all would be involved with that.
Orange Krush II
#13 |
#14 |
![]() Drives: '10 Camaro SS LS3 Join Date: Feb 2016
As far as sequential goes, I use a sequential kit from Phastek. Takes a good 10 minutes to install.
