Old 07-09-2016, 11:37 PM   #1
BravoMyles
BravoMyles's Avatar
Drives: Blue/Black 2017 1SS
Spraying on stock internals
Considering going the nitrous route. I know a guy that's stalled, cammed, and running about a 150 shot and says it's fine on stock internals. What's the general idea on that though?
2017 1SS - Hyper Blue Metallic
Heads, Cam, e85, 3600 Stall, Full bolt-ons, MBRP exhaust
2010 2SS - Summit White - SOLD
CAI intake, Borla Atak axle-back (Summit xpipe resonator delete), custom ported TB, Texas Speed 1 7/8" LT Headers w/ Catless connections
Instagram: bravomyles
BravoMyles is offline   Reply With Quote
Old 07-10-2016, 12:19 AM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
You can do a 400 shot on stock internals bro
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 07-10-2016, 12:54 AM   #3
BravoMyles
BravoMyles's Avatar
Or nah
Old 07-10-2016, 11:18 AM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Originally Posted by BravoMyles View Post
Or nah
If I went the nitrous route, I'd at least do a cam with supporting mods for that.
I don't know much about being on the bottle but I would think a ZL1 pump would be a good idea?
Old 07-10-2016, 11:51 AM   #5
flyer08
Drives: 2010 2SS/RS
Be cheaper to do a standalone unless you do the work yourself.
flyer08 is offline   Reply With Quote
Old 07-10-2016, 05:44 PM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
As long as it's progressive, you will have no issues running say a 200 shot. The stock engine is good for 800whp give or take. With Juice, its the sudden "punch" that will hurt the motor. So go progressive and enjoy.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 07-12-2016, 06:00 PM   #7
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
I'm on stock internals on a 150 shot. My mods are in my signature.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
