Old 07-17-2016, 12:29 PM   #1
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
Look What I Found Today
So I bought the car with aftermarket spacers and they did a crap job and the car and steering wheel shimmies at high speeds. I have had several people look at it and they all thought it was the tires or rims. After all those came back ok I found out about the spacer problem.
Anyways how do I get these rear spacers off look what he did. He welded the ends.
Flowmaster American Thunder Exhaust
timshifty is offline   Reply With Quote
Old 07-17-2016, 12:42 PM   #2
TC-2SS
Mike
TC-2SS's Avatar
Drives: 2011 2ss/rs
A carbide bit like is used to take burrs off engine blocks might work to grind the welds off. That really sucks though. Good luck!
TC-2SS is offline   Reply With Quote
Old 07-17-2016, 12:49 PM   #3
Coors9
Coors9's Avatar
Drives: 2011 Cyber Gray 2SS RS
Ouch...you're gonna have to get in there with a grinder and grind the welding enough so the nuts can unscrew. Get pass the welding and they should come off. You may need to put some heat on the nuts after the grinding to expand them . Helps them unscrew better if their seized. One at a time if you have to heat them and only heat the nut , not the stud. Quick heat will do it. If that doesn't work you may have to heat the nuts and quench them with water. I own a machine shop and have seen lots of that crap over the years.....good luck.
Coors9 is offline   Reply With Quote
Old 07-17-2016, 01:10 PM   #4
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
Thanks guys, unfortunately I live in an apartment so none of this can be done by me. I will have to make some calls tomorrow and see who can help me out. What a mess.
Old 07-17-2016, 01:11 PM   #5
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
What he says. Just take your time and they will come off.
KLR ZL1 is offline   Reply With Quote
Old 07-17-2016, 01:40 PM   #6
JusticePete
Drives: Camaro Justice
By the time you pay some one to clean this mess up, it may be cheaper to toss them in the garbage and get new hubs.
Old 07-17-2016, 02:15 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
This was my exact first thought when I saw the picture. Buy new hubs, most likely going to be cheaper and safer.
More to come.
Black_SS10 is offline   Reply With Quote
Old 07-17-2016, 02:30 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Agree with this^....Not worth the hassle, time and $$, and you'll have brand new hubs/bearings when your done. What a f'ed up job that was.... Good luck!
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 07-17-2016, 09:11 PM   #9
ksmrz
ksmrz's Avatar
Drives: 2010 Camaro
I'd try a grinder with a flapper disc on there..
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
ksmrz is offline   Reply With Quote
Old 07-17-2016, 11:38 PM   #10
8balldeluxe
Drives: 2010 Camaro SS Victory Red
Just start over dude, you'll be money ahead
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
8balldeluxe is offline   Reply With Quote
Old 07-17-2016, 11:54 PM   #11
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
You'd be there for hrs with a flapper wheel and not make any progress with it. Only tool that will make any kind of progress is either a carbide burr on a high powered die grinder or torch.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 07-18-2016, 12:17 AM   #12
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Just wow.
Deftones is offline   Reply With Quote
Old 07-18-2016, 06:15 AM   #13
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Originally Posted by Deftones View Post
Just wow.
Why don't you just buy new studs and use a breaker bar and socket to snap the welded studs off. You can then use a hammer and punch to knock what is left out of the hub and then fit the new studs.
Hub studs are normally replaceable
Stubbsy is offline   Reply With Quote
Old 07-18-2016, 08:03 AM   #14
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Plasma cutter the nuts off, it'll desttroy whats left of the stud also which you will have to replace anyways.
I would buy new hubs if you're not doign it yourself. It'll cost more in time x labor to get 10 of those off than it will be to pay for hubs and labor to replace them.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
