![]() Drives: Camaro SS Join Date: Jun 2013
I have searched, I see that the pilots Camaro drag by removing front sway bar. which improves performance by removing the front sway bar?
![]() Drives: 2015 2ss Join Date: Jun 2015
I unbolted mine if you are running skinnies it works great. I did notice with the stock front tires and street driving that it will follow grooves in the road big time and jerk the car around. Also a lot more body roll. As for the strip and slow mo videos it does seem to allow a lot better weight transfer
#3 | |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
I removed mine over 4 years ago no issues with driving. But you will have more body roll on hard turns.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
![]() Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
How much of an improvement in 60' or overall traction did you see MR. Nasty?
#6 |
![]() Drives: 2010 Camaro 2SS/RS L99 "The Reaper" Join Date: Jan 2014
I removed mine this year for drag racing....with BMR split drop springs (1.4" front and 1" rear) I have not seen much difference in handling. Like stated earlier it follows grooves in the road a little worse but overall not bad.
2010 Camaro 2SS/RS, L99
MODS: Texas Speed 1 7/8" long tubes, not cats | Borla S-type catback with X pipe | K&N Typhoon intake | FBM Tune | B&M 20,000btu tranny cooler | BMR split drop lowering springs | 20" black chrome Havoc wheels | gloss black calipers | smoked tail lights | black bowties | 25% window tint | debadged Best time slip: 12.902 @107.24mph 1.964 60' |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
3 years with it out mine
#8 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I don't have before/after, but the car weight transfers more.
Negatively affects handling as you would expect.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#9 |
![]() ![]() Drives: 2014 M6 ZL1 Join Date: Jan 2012
My Car went the other way badly with sway bar disconnected. Tried it on both MT Street Radial II and new MT street Rs. Car could not hook at all.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
#10 |
![]() Drives: 2015 ZL1 Join Date: Jun 2015
Maybe it's a mag ride thing?
Off subject are the M/T street R's better then the M/T street II's |
#11 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
It's an IRS and rear cradle bushing stiffness thing.
In any event, losing the front sta-bar on an IRS car will not help you as much as removing the front bar on a stock-suspended stick axle car (stock suspended meaning most anything other than a ladder-bar car). Mostly all you get is the weight reduction off the nose. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
#12 | |||
#13 |
Writer
I think taking off the sway bar helps even with IRS. My car works a little better.
Stick might be different. Got to keep the nose up with stick or u will unload the back.
PROJECT HEAVY CHEVY
#14 | |
![]() Drives: 2013 camaro LFX Join Date: Mar 2016
The cooper's are great in rain tho I hope to not lose handling during normal street driving |
