Old 07-21-2016, 01:41 AM   #1
Botoasy
Botoasy's Avatar
Drives: 2015 RRM 1LE
CNC Heads?
Car already has the following CAI, LT Headers, and a Cam. I'm at 470 rwhp, is it even worth installing new heads? If so what would the gain be roughly? Looking at about 1800 bucks for CNC heads. Thanks
2015 Camaro 1LE: CAI, LT Headerrs, Cam
2010 Camaro LS: BBK Longtube Headers with Hi Flow Cats, BBK CAI, SLP Loudmouth 1 exhaust, Magnaflow X-pipe and Resonators, Ported TB, Mace Ported IM and Spacer,Trifecta Tune, Elite Catch Can, Hotchkis front and rear sway bars. SOLD!!!
My Build Thread: http://www.camaro5.com/forums/showthread.php?t=272765
Botoasy is offline   Reply With Quote
Old 07-21-2016, 02:14 AM   #2
GenF-GTS
Drives: none
You can see what many different CNC heads are worth here compared to stock.
http://www.hotrod.com/how-to/engine/...er-heads-test/
From the results it indicates it's a lot of money for a small gain in HP.
GenF-GTS is offline   Reply With Quote
Old 07-21-2016, 02:31 AM   #3
Bo White
Bo White's Avatar
The only chassis dyno comparison I know of but not cnc.
www.camaro5.com/forums/showthread.php?t=445936
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 07-21-2016, 08:17 AM   #4
LaN-
Drives: 2014 SS Convertible
You can get TSP factory cast heads CNC ported for 900, but honestly I'm in a similar boat and say just put the money toward an LSA conversion.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525
Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings.
LaN- is offline   Reply With Quote
Old 07-21-2016, 08:57 AM   #5
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
If you plan on FI stay with the stock heads since porting isn't necessary. If you wanna stay N/A and want bigger gains, get more displacement. I wanted to stay N/A and if you check my sig you can see I made some nice tq gains with TSP heads. As my turner told me, its not just about individual mod gains but on how all the mods will compliment each other..
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty
alaskacamaro is offline   Reply With Quote
Old 07-21-2016, 09:07 AM   #6
JusticePete
Drives: Camaro Justice
Decide what your goals are for use, HP and TQ. Once you lock those down, there are a lot of people on this board that can help you get there.
Old 07-21-2016, 09:47 AM   #7
Bo White
Bo White's Avatar
My opinion is it's always a good thing to make things more efficient. Especially under boost....
Totalled:
Old 07-21-2016, 09:57 AM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
IMO not worth it, So little gain for the money. If your trying to sqeeze every last bit of power out of your engine, then hey go for it.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 07-21-2016, 12:06 PM   #9
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
The conclusion I have come to is if you have the motor apart it can be worth it to just do CNC heads. Make sure to mill them to boost compression, be aware of valve clearance.
If you already have it together it's not worth doing unless you go for some of the heads that change the geometry ex. TSP, Trick Flow, or Mast... still make sure to mill and bump up compression minding valve clearance.
With the right heads and your existing mods you could be at or over 500RWHP. Assuming the cam is up to it.
Drive ability is more important than Dyno numbers.
Firefighter is offline   Reply With Quote
Old 08-01-2016, 10:29 AM   #10
Jason 98 TA
Drives: Camaro
Texas Speed can get you setup with CNC porting of your stock castings for way under a grand. It'll gain about 25-30rwhp & put you right at that 500rwhp mark!!
Jason
Texas Speed
www.texas-speed.com
Jason 98 TA is offline   Reply With Quote
Old 08-02-2016, 04:19 AM   #11
Botoasy
Botoasy's Avatar
How would I ship them to get ported?
Old 08-02-2016, 04:33 AM   #12
Bo White
Bo White's Avatar
Go to Lowe's and get a Rubbermaid container and ship through USPS
Totalled:
Old 08-02-2016, 08:08 AM   #13
Firefighter
I think they have an option to send cores back and then you can reuse their shipping box. Less down time also.
Old 08-02-2016, 10:03 AM   #14
Jason 98 TA
Drives: Camaro
We sure might have cores. Last time I checked we had a few sets for exchange
