Old 07-24-2016, 07:06 AM   #1
mb13
mb13's Avatar
Drives: 2015 Z28 #980
Ported throttle body?
Saw a lot of talk before I signed up in the SS section about bo white and ported throttle body. I had a 2ss before I upgraded to the z28, but was wondering if anyone has ported the stock throttle body on the ls7? Slightly more throttle response? What else can be expected? Also am I seeing rite that the ls7 and the ls3 use the same throttle body? I'd like to purchase a 2nd oem one to have ported and keep the stock one intact.
Thanks
mb13 is offline   Reply With Quote
Old 07-24-2016, 08:45 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Don't waste your $. LS3 & LS7 throttle bodies are the same (90mm). If you upgrade the intake to a FAST 102 or an MSD, a 102 mm throttle body will fit. The 102mm is worth about 10rwhp according to the dynojet my car was strapped to when we did the swap. My suggestion would be to consider headers & a tune as first mods that actually help.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 07-24-2016, 09:41 AM   #3
mb13
mb13's Avatar
Thanks for the response. I want to do headers down the road, just rite now unsure of headers and a tune for the power train 100k warranty. I will have to check into the upgraded 102 intake along with the 102 throttle body. Thanks again
Old 07-24-2016, 10:08 AM   #4
Stephen12ZL1
Drives: '21 ZLE A10
The 102mm TB and intake will require a tune as well...and also insanely expensive for just a few hp. Intake, 102 TB, and tune will be in the $2k range.
Old 07-24-2016, 11:11 AM   #5
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Smile
Thanks
It's more for faster throttle response, rather than gaining HP. It makes a real noticeable difference, got mine from Bo. Didn't cost me $2K.
CreeperRS is offline   Reply With Quote
Old 07-24-2016, 01:03 PM   #6
D2M
D2M's Avatar
Drives: Z/28
The stock engine response is pure doodoo in the Z/28. Best bet is to buy a Vitesse throttle controller, minimal install effort and your warranty will remain intact. Its only a throttle controller so it will not change any engine tuning parameters so it will not offer the super crisp response a tune will but its definitely a step up from stock.
D2M is offline   Reply With Quote
Old 07-24-2016, 02:47 PM   #7
Stephen12ZL1
Drives: '21 ZLE A10
Still not worth it IMHO...the throttle controller that helps the soggy LS7 feeling is a better choice
Old 07-24-2016, 02:59 PM   #8
CreeperRS
CreeperRS's Avatar
I you want something unreliable, then yes. Otherwise BW PTB is the way to go.
Old 07-24-2016, 10:15 PM   #9
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Stephen, what headers do you run? My driend bought 1 7/8" stainless works and even at parking lot it hits steering shaft, dimpled half inch and still hits so had to put solid engine mounts... With your grip I figure issue is bigger so curious what you run?
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 07-25-2016, 08:52 AM   #10
Stephen12ZL1
Drives: '21 ZLE A10
The only choices for the Z/28 are American Racing and Kooks. I have the American Racing and they fit perfectly. Kooks fit perfectly as well and I believe that their quality is similar when comparing the two. I modified nothing to install the headers on my Z/28 and the steering shaft clears by a lot. On a ZL1, the last set of Stainless works fit great and didn't require any mods to the steering shaft boot or otherwise.
Old 07-29-2016, 01:54 PM   #11
Pat evil black Z/28
Pat evil black Z/28's Avatar
Drives: 2015 camaro Z/28
Stainless work don't make header to fit the z/28. That why you had hammer on them.
Black 2015 camaro z/28 #445 with ac
Pat evil black Z/28 is offline   Reply With Quote
Old 08-04-2016, 06:26 PM   #12
68camaroz28
68camaroz28's Avatar
Drives: 68 Z28, 69 Z28, 2015 Z28
I would think the ported throttle body would potentially void your 100K power train warranty as well!
68, 69 & 2015 Z/28's
68 Z/28 Restoration Thread on Team Camaro
http://www.camaros.net/forums/showthread.php?t=182584
68camaroz28 is offline   Reply With Quote
