Old 07-24-2016, 07:38 PM   #1
matt99199
Drives: 2014 2SS L99 RS Chevy Camaro
Oil cap for the valve cover?
I took off my oil filler elbow on my 2014 2SS camaro only to find out that the cap has a single notch in it when the filler tube has two.....I managed to butcher my cap with a dremel and make it work for now but are there any caps out there that can be applied right to the valve cover? I was looking at maybe putting on a breather cap considering they can be but I didn't know if it was counter intuitive with a catch can already installed on the PCV line?
matt99199 is offline   Reply With Quote
Old 07-24-2016, 07:45 PM   #2
failshift
Banned
Proform 141-615 Grommet Set https://www.amazon.com/dp/B000BRC1U4..._gmvLxb5J1KSVC
Proform 141-616 Push-In 3" Air Breather Cap https://www.amazon.com/dp/B0006B3W9E..._GmvLxbFT6BEMR
failshift is offline   Reply With Quote
Old 07-25-2016, 07:13 AM   #3
TX_ED_SS
TX_ED_SS's Avatar
Drives: 2010 2SS/RS Inferno Orange
Matt,
I have a Metco Motorsports Breather (only used for a month) I'll sell you for cheap. PM me if interested.
U.S. Army Retired
TX_ED_SS is offline   Reply With Quote
Old 07-25-2016, 05:33 PM   #4
matt99199
I did some research and I think I just want to get a solid cap with no breather. Does anyone know of a cap that can be put right on the valve cover?
Old 07-25-2016, 05:35 PM   #5
failshift
Banned
Proform 141-630 Push-In Oil Filler Cap https://www.amazon.com/dp/B000630I58..._6xOLxbS8H5KDW
Old 07-25-2016, 10:56 PM   #6
Subzero
Subzero's Avatar
Drives: Black 2012 2SS/RS Convertible
I've gone through two of those - they shrink when exposed to heat for some odd reason. I was leaking oil from my cap after replacing my valve covers with pro-form equivalents.
As those are meant for a 1.22" size hole, I'd highly suggest looking for something slightly larger - like 1.23-1.25" - They'll be a little snug at first, but will loosen over time.
I personally have the K&N breather - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Subzero is offline   Reply With Quote
Old 07-25-2016, 11:51 PM   #7
failshift
Banned
Why I suggested the proform grommet to pair it above
Old 07-26-2016, 07:40 PM   #8
Subzero
Subzero's Avatar
It looks like I'll have to try that route now too. My K&N has shrunk to the point of leaking again.
Old 07-26-2016, 07:41 PM   #9
failshift
Banned
I run this Elite Clean Side catch can
(Uses the proform grommet above)
http://www.jdpmotorsports.com/manufa...9-lt1-elitecas
Old 07-26-2016, 09:02 PM   #10
Subzero
Subzero's Avatar
So essentially, this is an oil cap and a catch can all in one? Nice find!
Old 07-26-2016, 09:03 PM   #11
failshift
Banned
Only clean side though. Just keeps the air coming from the crank case into the intake tube from having oil in it
Old 07-26-2016, 11:08 PM   #12
Subzero
Subzero's Avatar
I can see that there is a secondary part that screws into the existing oil cap which allows the can to push in.
Would you happen to know the OD of the bottom portion of the can that pushes in?
Old 07-26-2016, 11:10 PM   #13
failshift
Banned
No. But it fits right in that grommet above. That's the exact grommet/link I bought/use
Old 07-26-2016, 11:13 PM   #14
Subzero
Subzero's Avatar
Thanks - I'll try that. Do you think a catch can is also necessary, even if you're not boosted?
breather cap, cap, filler, oil, oil cap
