![]() ![]() ![]() ![]() ![]() Drives: ZL1 Join Date: Sep 2011
AGP Twin Turbo Owners
Hey I have searching through the FI forums to find AGP owners and their setups and what they make
I think if we can have ONE thread where as many can post what they have Turbos: Motor (CI): Cam: Trans: Fuel System: Meth: E85: Installed/ Tuned by: Horsepower/Torque Numbers at Boost level: 1/4 mile time/speed: 1/2 mile speed: Standing mile speed: Just a thought
Maybe also add cam as well, but I like this idea
Turbos: 54/57 JournalBearing --- .63 a/r Stock 6.2 Stock Cam 6 speed manual stock clutch Fuel system 850 injectors and msd bap Meth/e85 none Self installed and self tuning in progress with agp base tune as the starting point Running max 8 psi and hp & trq numbers are n/a hopefully will dyno in the future
Cai intake and a few other mods😎
Thanks will update
![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
1/4 times would be a nice add on since there's not much of that around
Good idea will update
#6 |
Too much is never enough!
Turbos: Twin 54/57's journal bearing
Motor (CI): bored ten over forged rods and pistons 9.3:1 Cam: 231/ 239 @ .050, .617/ .624 lift, 113 LSA Trans: Stock M6 with Mantic 9000 twin disk clutch Fuel System: Livernois dual pumps and ECS BAP Meth: Alky Control Dual nozzle E85: No Installed/ Tuned by: FSP ttshovel and myself Horsepower/Torque Numbers at Boost level: On the dyno.....was 800ish at 13.5 psi getting tuned as of now. ZL1 rear DSS aluminum drive shaft and DSS 1000whp axles Best 1/4 mile time on old setup was 11.19
Build thread http://www.camaro5.com/forums/showth...55#post8107855 Last edited by 1KillerSS; 07-27-2016 at 04:58 PM. |
#7 |
![]() Drives: Twin turbo G8 GXP Join Date: Dec 2012
Turbos: BW S256sx 56/61 .82
Motor (CI): 417 10.3:1 Cam: GT9 Trans: Stock 6l80 Fuel System: CTS-V pumps, Vaporworx controller, JMS booster, ID850'S Meth: Pro Meth single nozzle, 80/20 mix E85: Yes, 50% Installed/ Tuned by: Installed by L&S garage, tuned by Justin White, speed density Horsepower/Torque Numbers at Boost level: 821/801 @ 14 psi 1/4 mile time/speed: 10.172 @ 144.95 1/2 mile speed: Not likely Standing mile speed: Even less likely Last edited by Unavowed; 03-02-2019 at 11:06 AM. |
#8 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Turbos: BW 56/61mm journal
Motor (CI): 376 (stock rotating assembly) Cam: BTR Turbo Stage III cam 230/235 .609"/.610" 114+4 Trans: stock TR6060 Fuel System:LPE Twin-Fuel with KB BAP thru ID-1000's Meth: No E85: Flex-fuel sensor Installed/ Tuned by: Tuned by Precision Tuning Concepts and myself Horsepower/Torque Numbers at Boost level: 804rwhp @ 5,400rpm @ 11psi, 804ft-lbs @ 4,950rpm @ 11.7psi boost on E85 1/4 mile time/speed: 10.897@128.18 DA7724ft (benchracer sea level est 10.4@139) 1/2 mile speed: Not run (yet) benchracer sea level est 16.1@169 Standing mile speed: Not run (yet) benchracer sea level est 25.8@194
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily Last edited by dreksnot; 10-02-2016 at 10:25 PM. Reason: updated 1/4 mile results |
#9 |
Thanks guys lets keep it going
#10 |
![]() Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
Turbos: EFR7670 57/70 BB .82 Motor: stock everything Cam: no. Transmission Tr6060 all stock,stock clutch( in future triple monster or HE) Fuel: id850 injectors stock pump( 1le got zl1). Meth: AGP methanol kit. E85 no( in future AGP flex kit). Installed by me Tuned by Eric at Crucial Performance. Horsepower/ Torque 12psi 672whp 695wtq. 1/4 mile run first time on track with this car last weekend on 97degree humid day 12.2 trap 121mph- so basically suck.
#11 | |
Was it spinning? Good trap speed |
#12 |
In what universe is 121 a good trap speed for 672 rwhp?
Seems that it was a combo of poor track prep, terrible air, and the need for more seat time. I would expect a trap @ 130 with that power, especially with a manual. It may never et great for that reason, but trap speed should be higher. I'm sure the weather cost @ 50 rwhp that day though. |
#13 |
"Cam Only"
Yeah I was gonna say, I trapped 119 with just a cam and headers at 483rwhp lol
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq |
#14 |
Lol shows how much I know
