Old 08-10-2016, 02:25 PM   #1
Lio Martinez
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
¡HELP NEEDED!! Will Z/28 Carbon ceramic brake set up fit a 13 1LE?
Hello I decided to drop by here with the experts before I do anything else .
I initially bought a full used OEM Kit of the Z/28 brake kit ( calipers, brake pads, Carbon ceramic rotors )
The rotors were damaged so I got my money back on those and payed to keep the brake pads and calipers . So now I'm trying to get the rotors .
Will the Z/28 Brembo brake set up for my 13 1LE? Or will I have to modify , cut anything to make them work ?
Lio Martinez is offline   Reply With Quote
Old 08-10-2016, 03:12 PM   #2
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
I am not 100% sure if the wheels will fit it correctly but the spindles and everything are the same so yes all of that should bolt right up.
Just be mindful of pad wear as your car will not have the sensors like the stock cars do.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 08-10-2016, 04:12 PM   #3
Lio Martinez
I want to buy also brake lines ? Will they fit ?
Old 08-10-2016, 04:15 PM   #4
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
It should fit as the Z/28 runs a 19" wheel and you have 20"s stock. But I could be wrong. There are a couple guys who have swapped them. Check the road course subforum.
Sent from my campfire using smoke signals
Superman09 is offline   Reply With Quote
Old 08-10-2016, 04:38 PM   #5
Chassis side connections are the same on all cars, just length varies.
A Z28 line is plug and play on your car.
Old 08-10-2016, 04:55 PM   #6
Lio Martinez
You are selling some new braided performance brake lines correct?
Old 08-10-2016, 05:01 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
it will fit, but you have to use the Z/28 rotors, will not work on the 1LE rotors.
