08-11-2016, 04:16 PM | #1 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
cadillac ATS brembo calipers for LFX
I ordered a new pair of front ATS brembo calipers from dealer(22760030/22760031) for $246.... does it require a caliper pin kit? I already have a set of non drilled/slotted black zinc rotors on my car ... what pads would you suggest?? Also what would be the rear upgrade....
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
08-11-2016, 04:51 PM | #2 |
Drives: 2011 RS Join Date: Apr 2011
Your V-6 rotors won't work, they are too small. You'll have to get SS rotors. Yes you will need pins kits, and... brake lines. Most people would replace the caliper bolts as well. You'll also have to trim or replace the dust shields, it's easy to trim them. The rotors in the pic are of the rear rotors, but the front SS rotors are bigger than stock V-6 rotors.
08-18-2016, 04:06 PM | #3 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Are the ATS calipers the same as the CTS V six-piston units?
Meh
08-18-2016, 04:31 PM | #4 |
Tri-County Camaro SWFL
No. the ATS appear to be the same as the normal SS calipers. The front on the ATS are 4 piston brembos and the rear are a standard 2 piston. I would say try it out since you already ordered it.
08-25-2016, 02:11 PM | #5 | |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
08-26-2016, 12:37 AM | #6 |
Drives: 11 Camaro V6 RS, 03 BMW Z4 Join Date: Oct 2013
I'm not an expert on this topic, but I just put the ATS Brakes on my 2011 V6. My kit came with pins and pads. I've linked the post where I first heard of the upgrade and also some pics of my car (post 41) in the second link. I have Goodridge stainless braided brake lines and some after market drilled and slotted rotors. It all went together pretty nicely except for a banjo bolt that was the wrong size.
http://www.camaro5.com/forums/showthread.php?t=432631 http://www.camaro5.com/forums/showth...=326653&page=3 |
05-22-2017, 08:23 PM | #7 |
Drives: Crystal Red 1SS Coupe 6spd manual Join Date: Nov 2014
We just did the Caddy conversion on my Son's V6. Used banjo bolt #23372321.
01-24-2018, 04:36 PM | #8 |
Drives: Camaro lt Join Date: Apr 2014
Has any one tried to put 2016 camaro brembos on a 2010 camaro?
