![]() Drives: 2014 Ashen Grey Camaro LT Join Date: May 2016
Steering wheel question
Does anyone know if GM make a flat bottom steering wheel with stone stitching for a 2014 auto? I cannot find one. If anyone knows I would like to get a part number. Thanks
![]() ![]() ![]() ![]() Drives: 2011 2SS Join Date: Mar 2015
I don't think a flat bottom was offered until the 6th gen, although there are some aftermarket ones I think
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
Obsessed Much?
Drives: 2015 Silver 1SS/RS M6 Join Date: Aug 2009
The Z/28 wheel is flat bottomed. Not sure if GM sells it directly though.
edit: Found it on Ebay part number 22954889
2015 1SS RS M6
I can find red stitched ones but how would it look with red stitching in the steering wheel and stone everywhere else? Don't want to dye the other stitching
That's for a manual....looking for a auto
#6 |
You'll probably have to get an aftermarket one. Phastek has some
2011 SS L99
#7 |
2011 SS L99
#8 |
Looking for one for a 2014 model
#9 |
![]() Drives: 2015 2LT SW RS A6 Join Date: Feb 2016
Check gen5diy.com they used to have used zl1 flatbottom for less than aftermarkets.
#10 |
'It's an experiment'
ZL1 steering wheel is at least half the Phasetek price new and you already have the right air bag... A6 has the paddles so I don't think the Z28 will function correctly with out mods...
-Don |
#11 |
My bad the gen 5 wheels are new ones, sorry.
#12 |
![]() Drives: 2013 2SS/RS Convertible Join Date: Jun 2015
Best you can do is the zl1 wheel with red stitching. If you don't like the red, there a thread somewhere on how to restitch it to a new color. Looks like a pain though
Sent from my SM-N920V using Tapatalk |
#13 | |
Restitch
I bought a suede flat bottom out of a 1LE but all LEs are manuals with stone stitched, now the ZL1s do have auto's but have red stitching. Now you can restitch it like I did it only took a few hours and the cost it self was fairly minimum just bought orange thread from www.thethreadexchange.com in .207 size approx. 8 bucks, I don't remember if they had a stone stitch or not, and a few needles from Hobby Lobby. It wasn't all that bad just a bit tedious but when your done you'll have one of a kind like I do. Reference YouTube on how to restitch it. If you want some pics PM me and I'll txt them to you... https://www.superiorthreads.com/shop...prox-1498-yds/ This might be a good option.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components. Last edited by olblue75; 08-12-2016 at 10:46 PM. |
#14 |
Here you go a automatic wheel.
http://www.camaro5.com/forums/showthread.php?t=461861 Gen5DIY offers a SS steering wheel bezel for a flat bottom wheel. Don't believe you'll find a LT bezel unless you do something custom.
Orange Krush II
