Old 10-07-2009, 07:01 PM   #1
carguy50
carguy50's Avatar
Drives: 2SS/RS, Sequntials,Tune,Flomstr,CAI
Thumbs down PI$$ POOR SERVICE DEPARTMENT
OK guys, I have been in the hot rod world for 40 years. I have never been bull$hitted like I was today at the Service Department of Champion Chevy in Corpus Christi TX.
I picked up my new 2SS/RS less than two weeks ago. I noticed it had hesitation of about 1 second off the line no mater how easy or hard I accelerated. I figured it was the cheap Dealer gas, they are required to fill you tank on delivery. I drove it a couple days, with no improvement. I filled the tank with Shell 93 octane and put in a new K&N air filter. I drove that tank out and Filled up again with Shell 93 octane. No improvement, so I took it to the Dealer where I bought it. Champion Chevy of CC TX.
I took it in at 0645 hrs this morning. I explained the problem and the service idiot said he would get on it at 0700. I checked back at 11am.They had not touched it. About 130pm this bonehead calls and tells me my K&N Air filter is causing the hesitation. he needs me to bring in the stock AC filter so the Tech can get a true MASS AIRFLOW SENSOR reading, Because the Sensor was FLUCTUATING.I went home,got him the stock air filter and was told the GLOBAL DIAGNOSTIC SYSTEM is DOWN and they can't get any Board Powertrain Control Systems at this time. Come get it and see what happens.
I have used 30 or 40 K&N stock box and cold box systems over the last many years and never had a negative response, it has always helped both power and response time.
I Could be Wrong, But I seriously doubt it. Please let me know if you have ever experienced this problem.
I pulled # 5 and 20 fuses and will let it sit overnight and check it tomorrow. HELP!!
carguy50 is offline   Reply With Quote
Old 10-07-2009, 07:03 PM   #2
BLACK10
BLACK10's Avatar
wow
Old 10-07-2009, 07:05 PM   #3
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Was going to suggest the #5 & #20 pull but you've got that covered. Other than that, it sounds like you're dealing with a true winner. blaming the K&N filter sounds a bit suspect to me but hey what do I know. Good luck!
Old 10-07-2009, 07:07 PM   #4
djsnoflake
Faith Keeper
djsnoflake's Avatar
Pulling the fuses could help you.
As a side note, lots of dealers are dicks about K and N. Some dealerships even will go as far as to void your warranty. They say that the oil in the filter interferes with sensitive MAF's. Not saying that is true, just saying what I have heard.
Old 10-07-2009, 07:08 PM   #5
jrboyd_1980
A ***'s Headache
jrboyd_1980's Avatar
Drives: Everything
If your dealership can't do anything and you get desperate and feel like making drive to McAllen, let me know. I can pull your car history from here with VIN and we can see what they did and know we have top rated service department in South Texas Region.
jrboyd_1980 is offline   Reply With Quote
Old 10-07-2009, 07:09 PM   #6
tones2SS
tones2SS's Avatar
Thumbs up
So, did they diagnose the problem? Or just blow smoke up your butt?
What bothers me the most is when they say that they are going to look at it right away, the car sits for hours before they ACTUALLY do touch it. Yeah, that stuff makes me mad!! lol
I would try disconnecting the battery for a couple of minutes and then try a reconnect and see if that resets something.
GOOD LUCK!!
Old 10-07-2009, 07:09 PM   #7
jrboyd_1980
A ***'s Headache
Drives: Everything
Dealers can not void the warranty. That has to come from the Regional Service Advisor. But he can definately do it.
Old 10-07-2009, 07:14 PM   #8
Bellringer
Bellringer's Avatar
Drives: my wife nuts.....
Where else would another dealer offer to help fix someone elses brain fart? Heres a tip of the hat.
PS. Thanks for helping me out today as well..
44030 is all mine!
GM
Bellringer is offline   Reply With Quote
Old 10-07-2009, 07:14 PM   #9
jrboyd_1980
A ***'s Headache
Drives: Everything
No problem. Glad could help. That's what we here for.
Old 10-07-2009, 07:19 PM   #10
carguy50
carguy50's Avatar
jrboyed, please send you fax # to me At" carguy50@juno.com"and I will Fax the service ticket to you.
Thanks
Old 10-07-2009, 07:24 PM   #11
carguy50
carguy50's Avatar
I've got the smokiest butt in Corpus tonight. they did not fix anything. But in their defense, it took them all day to not fix it.
Old 10-07-2009, 07:25 PM   #12
jrboyd_1980
A ***'s Headache
Drives: Everything
956-686-2984 Fax Number
I can pull up the info with VIN to from website.
Old 10-07-2009, 07:36 PM   #13
carguy50
carguy50's Avatar
got it, thanks, its on its way. VIN 2G1FK1EJ0A9142781
Old 10-07-2009, 08:16 PM   #14
Speedfreak
Drives: 1999 30th Anniversary Trans Am
Speedfreak is offline   Reply With Quote
Sept 12th 09 Reva Fire Department Car Show Pictures!!! Camaro68 General Automotive + Other Cars Discussion 0 09-14-2009 09:58 AM
