Old 08-13-2016, 08:01 PM   #1
Dhaliwal559
Dhaliwal559's Avatar
Drives: 2015 Chevy Camaro 1LT/RS
What the hell happened to my car?
I was just driving home and then boom.
Have a good day!
Dhaliwal559 is offline   Reply With Quote
Old 08-13-2016, 08:04 PM   #2
Dhaliwal559
Then shut off car for 5 min, and back on. The lights went off except for check engine light? By the way, don't worry about the tire sign, that's been on because I don't have TPMS right now due to just got new wheels and waiting on them
Have a good day!
Old 08-13-2016, 08:04 PM   #3
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
you tipped it on it's side
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 08-13-2016, 08:08 PM   #4
Tortugas12
Tortugas12's Avatar
Drives: 2013 2SS/RS Convertible
You have a VTC?
Sent from my SM-N920V using Tapatalk
Tortugas12 is offline   Reply With Quote
Old 08-13-2016, 08:11 PM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
What mods do you have? What are the codes?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-13-2016, 08:13 PM   #6
Dhaliwal559
Yes I have a VTC.
And I have
Overkill Tune
E85 kit
JacFab intake spacer
JacFab 80MM ported intake manifold
RotoFab intake
Vitesse throttle controller
Overkill 80mm throttle body
Elite catch can
Have a good day!
Old 08-13-2016, 08:14 PM   #7
ZiG
ZiG's Avatar
Drives: 2011 2SS/RS LS3
+1, what codes did it throw? Assuming you thought to check?
2011 2SS/RS LS3
Rotofab CAI/scoop/washer - FE4 conversion - Pfadt ZL swaybars - BMR endlinks - Hurst short shifter - RKSport spoiler
ZiG is offline   Reply With Quote
Old 08-13-2016, 08:14 PM   #8
Dhaliwal559
Haven't got a chance to see what codes are being thrown. My cousin is bring his code reader and I'll see.. I hope it's nothing serious. Don't want to go to a dealer since I'm really not stock anymore. I have a 2015 1LT/RS with 16,500 miles
Have a good day!
Old 08-13-2016, 08:15 PM   #9
Tortugas12
Tortugas12's Avatar
This is a very common problem with the VTC. Happened to me once, I turned the car off and unplugged it, ran it for a day then reinstalled it. I didn't have problems again
Old 08-13-2016, 08:20 PM   #10
Dizzy82
Dizzy82's Avatar
I got the Throttle Sensor Position Error about a week ago. I unplugged my VTC, plugged it back in then re-calibrated it. No problems since then.
Old 08-13-2016, 08:20 PM   #11
Dhaliwal559
You think it's the VTC then? I heard that was a problem with the first ones that came out, but mines only about 1-2 months old. Bought brand new.
Also on other threads, I read it might be throttle body? I don't even have the stock throttle body anymore..
Have a good day!
Old 08-13-2016, 08:22 PM   #12
Dizzy82
Dizzy82's Avatar
Try re-calibrating it, if that doesn't work run without it for a while. If the codes don't come back, there was an issue between the VTC and your other throttle mods.
Old 08-13-2016, 08:26 PM   #13
Dhaliwal559
Okay I'll keep you guys posted, thank you
Have a good day!
Old 08-13-2016, 08:29 PM   #14
Tortugas12
Tortugas12's Avatar
You're going to need the codes to know for sure. When I pulled my code they explained it that with drive by wire they potentiometer in the pedal sends a signal to the throttle body. This is interpreted as a command on how far to open.
These two values are checked against each other and if there is a big enough difference the code gets thrown. What the VTC does is changes the signal to make the tb think you're hitting the pedal harder but the throttle potentiometer will still show your actual input. This is what can cause a problem.
Having the 80mm tb may make this problem worse, can't be sure though
Reduced power mode is trying to save your engine if there is a real problem with the system
check engine light, reduce engine power
