Old 08-13-2016, 08:09 PM   #1
vince.cuevas
Drives: 2013 1LE Camaro white and Black
2013 1LE rear diff fluid change
If you have accomplished what type of fluid did you use? and how much is needed?
vince.cuevas is offline   Reply With Quote
Old 08-13-2016, 08:46 PM   #2
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
Royal Purple Max Gear 75W-90 High Performance Synthetic Automotive Gear Oil - 1 qt. Is all you need.
Sent from my SAMSUNG-SM-G890A using Tapatalk
keith.wilkinson.10 is offline   Reply With Quote
Old 08-14-2016, 12:38 PM   #3
ASimmons04
Drives: 2015 AGM 2SS RS 1LE
What he said ^
ASimmons04 is offline   Reply With Quote
Old 08-15-2016, 11:07 PM   #4
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
This Vince, can't go wrong with this. Comes pre mixed.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 08-15-2016, 11:10 PM   #5
LT1Zob
LT1Zob's Avatar
Oh, and mine took just a little over one bottle, so buy 2
Old 08-16-2016, 03:58 AM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Dont forget friction modifier!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 08-16-2016, 07:14 AM   #7
L99CAMA2011
L99CAMA2011's Avatar
Motul 75-90LS, Redline 75-90LS. Janetty shop recommended 85w-140 Lucas diff fluid plus 4oz. friction modifier.
Old 08-16-2016, 08:15 AM   #8
vince.cuevas
thanks guys ordered the ac delco and a pump just in case
Old 08-16-2016, 08:26 AM   #9
keith.wilkinson.10
Not all oils need modifier. Royal Purple does not need modifier.
Old 08-16-2016, 09:08 AM   #10
20152SS1Le
Drives: 2015 Camaro SS 1LE
no modifier for redline either
2015 1LE Red Rock- Recaros, NAV, and NPP
BMR 1" lowering springs and Bilstein B6 monotube shocks/struts
Rotofab CAI
Elite engineering catch can
Texas Speed 1 7/8 long tube headers and Cats
GPI Rod mod and ported intake
Ported throttle body
JRE tune
20152SS1Le is offline   Reply With Quote
Old 08-16-2016, 09:29 AM   #11
1LEJNG
Drives: Red Hot 2014 1LE
1LE Knob
gajagfan,
I have one I'm not using. Send me $50. I'll pay for shipping.
I have a 14 hood that's not being used too. Freshly wrapped w/carbon fibre wrap down the middle. Just hanging on my garage wall.
1LEJNG is offline   Reply With Quote
Old 08-16-2016, 09:41 AM   #12
Freddy G
Freddy G's Avatar
Drives: 2014 Camaro 2SS 1LE /2011 2LT
Originally Posted by 1LEJNG View Post
gajagfan,
Wrong thread?
Freddy G is offline   Reply With Quote
Old 08-16-2016, 11:24 AM   #13
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
gajagfan,
jcampos is offline   Reply With Quote
1le, diff, fluid, oil, rear
