Old 08-14-2016, 02:46 PM   #1
Themarowagon
Drives: Black ss
Long tubes with cats X-pipe, and Borla atak?
Okay so I want to add some long tube header for their performance but Im afraid it will be too laud with my borla atak. So i was thinking if i add some cats to the LT and an X-pipe, would it reduce the noice of the longutbes?
P.S. if you guys have any idea on how to reduce the noise of the LT please let me know. Also, My camaro is my daily driver and i wake up at 3 am to go to work so i dont want my neighbors on me all the time.
Themarowagon is offline   Reply With Quote
Old 08-14-2016, 08:09 PM   #2
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Well long tubes will definitely wake the car up, both in sound and performance. Given that you have Borla's Atak catback it will definitely be loud. Adding high flow cats will reduce some of the rasp that your exhaust will have, but it won't likely knock down the volume much. Given that you live in LA you may not even be able to use LT's due to California's crazy strict exhaust/emissions regulations.
Check out my build thread
Old 08-15-2016, 08:44 PM   #3
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Worst case, you buy an S-type axleback and swap the mufflers. That's what I did.
MarylandSpeed is offline   Reply With Quote
Old 08-22-2016, 04:34 PM   #4
OnebadSS - 2013
OnebadSS - 2013's Avatar
Drives: 2013 Camaro SS - Blue Ray Metallic!
When I was just bolt ons I had headers with cats, Magnaflow x Pipe, deleted resonators and a Borla ATAK, didn't think it was too loud at all. It's only loud when you're WOT and really that's about it, you won't have bad cabin noise. Shit even with my SS4vvt cam from GPI I still don't have any drone.. I never understood why people complained about the ATAK but maybe that's just me ��
SS4VVT GPI, ported/milled heads, GPI radius rod insert manifold, Circle D 5c 4k triple disc stall, 3.91 gears, kooks 1 7/8+HF cats, Magnaflow X Pipe-Deleted Resonators, Borla ATAK, Vararam DRX, VMAX CNC ported TB, BMR Toe Rods, Trailing Arms, Front/Rear Sway Bar, 1.25" lowering springs, LCA. Tuned by Ryan at GPI.
OnebadSS - 2013 is offline   Reply With Quote
borla atak, long tubes, ls3, lth, x-pipes
