![]() Drives: . Join Date: Jun 2016
Air Jacks, Centerlock wheels..?
Simple question really, has anyone fitted these to their Z/28?
If not Z/28, has anyone seen another Gen5 Camaro with Air Jacks fitted and have any pictures or a link to a build thread? Similarly does anyone make a centerlock wheel conversion for Camaros? Both mods are something I'd consider for frequent track use as I'll likely have at least a couple of sets of wheels and tyres (buying centerlock alloys is fairly easy for me in the UK). cheers, Patrick |
Drives: Camaro Justice Join Date: Jun 2007
Forgeline has center lock wheels.
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
its not clear..an air jack to help jack the car up at the track??
Aren't those like floor jacks they use, why would you put an air jack into the Z/28's signature DSVV suspension pray tell, or the extra weight??
![]() Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
#4 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I'm assuming one would remove weight elsewhere to make up for the extra weight (not much at all) that an airjack system would add.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
#5 | |
Raging Bull Reborn
I've been to Hallet near Tulsa in mine, and theres no reason to have a jacking system installed, perhaps if you track a lot..a tow hook? I didn't see him in the registry, just a non owner wanna-be asking the Z/28 owners a dumb question
#6 | |
Yes I plan to track my car a lot. I don't have it yet although I have already parted with a deposit.. ![]() Generally air jacks only add 10kg to the car's weight, a small price to pay for the convenience at the track. The car will be getting tracked including in the rain so will have sets of wheels with wet tyres fitted. I've been doing some reading up on the subject and have a good idea of the spec of jacks to use, Nitrogen tank and handling safety, and pressure required to lift a Z/28. My question was really regarding if anyone has seen them fitted to a Gen5 Camaro so I could look at where they had found to position them around the sills/subframes. There's quite a few Corvettes running with them and I've seen on BMWs, R35GTRs and obviously common on Porsche 911s so I imagine it will be possible to fit them somewhere ![]() thanks for the trip regarding Forgeline wheel Pete, will give them a look. ![]() cheers, Pat |
#7 |
![]() Drives: Too many Join Date: Mar 2016
You're right it would make time at the track much easier.
If you are ultimately going to do some form of amateur racing........... some have rules against it so try and consider that when making your decision. And don't forget to post pics. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 1LE Join Date: Nov 2013
I've been waiting for someone to install air jacks on one of these...
#9 |
![]() Drives: 2017 Corvette ZO6 & 2021 Camaro LT1 Join Date: Jul 2016
With a car the weighs almost 4000#s you will want to possibly use angle iron or other reinforment where attached to the frame to spread the load.
#10 |
Drives: G5.R Join Date: Sep 2010
We were going to use air jacks on our car but decided against it as it added an extra50 lbs.
We are having Forgeline make us a set of one-off enter lock wheels on our G5.R. |
#11 |
![]() ![]() Drives: 14 Z/28 0# Join Date: May 2013
http://prattmiller.com/ builds all of GM's race cars they will have all the info you need
"PTM11" Search & Destroy
#12 | |
#13 |
Raging Bull Reborn
Pat
No offense, we see a lot of stuff posted by POSERs on the forum, so if your an owner, register in the registry and welcome aboard. However th weight of the car isn't like a Z06, you'll need to do something work to distribute the weight. The more you do the more weight you add. Good luck with the purchase, as you'll find it just about the best bad azz car there is-completely sinister and early (not quite) Z06 fast.
![]() Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 Last edited by The_Raging_Bull; 08-19-2016 at 09:32 PM. |
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
Tags |
air jacks, centerlock |
