Question to the people that have installed an LSA
I will be putting an LSA on my LS3 within the next couple of weeks and I'm debating if it will be a lot easier to do a cam at the same time or if it won't save that much time and just do it later ? also any idea if an ADM stage 2 PD cam will lower the boost slightly vs the stock LS3 cam ?
Thanks |
Keeper of “THE list”
Personally I'm waiting to upgrade to a supercharger until I can afford the cam too. Of course I have a L99 and I'll be pulling the heads to change the lifters at the same time so for me it is well worth waiting to do it all at once.
'It's an experiment'
I think you know where I'm at. I did the cam et. al. at the same time.
-Don
747 RWHP 794 RWTQ
![]() ![]() Drives: 2011 Camaro 1SS Join Date: Feb 2016
Having mine done at the same time.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
do it at the same time!
#6 |
Banned
Drives: Camaro Join Date: Mar 2013
I found it easier to just pull the LS3, put it on an engine stand and swap in a LSX B-8, cam, springs, LSA SC all at the same time.
#7 |
But if I do a cam now what will I do in 2 months when I'm not happy with 550rwhp ish ? lol .... Idk I already have about $4400 into this with me doing all of the work swallowing another 800 for a cam and springs etc... kind of pushes it over the edge but I know I SHOULD do it at the same time as it will save some steps.... Anybody have a guess to the hp ? Ls3 with lsa 2.75 pulley, 2" primary LT headers, no cats, full 3" from headers back through a pair of flowmaster mufflers, ADM CAI, ADM fpcm, 65lb injectors (already have ZL1 pump). What will hp be with and without an ADM stage 2 PD cam and will my boost pressure drop slightly with the cam ? I'm thinking 540rwhp without cam and maybe 580+ with it but just guessing ?
p.s. the car dyno'd 386/386 100% stock on Jannetty racing's dyno (not sure what kind of dyno they have and if it's stingy or beneficial to numbers). |
#8 |
"Cam Only"
Do it all at once.
You'll end up doing it later and having to rip apart things again. And then have to pay for a retune etc. Just do it all right the first time. I waited until I had all my pieces together before I did it. I even waited till I had the money to drop on my fuel system because I knew I wanted to do E85.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq |
#9 |
So I decided to go with the Stage 1 PD cam and the tooley .660 valve spring kit. Any idea's what the stage 1 pd cam along with the 2.75 pulley, LT headers and full 3" exhaust along with ADM cai w/scoop are making on an LS3 ?
#10 |
Andy gave me this -- not sure which pulley they installed (electric PS)...
http://www.camaro5.com/forums/showpo...0&postcount=87 -Don
747 RWHP 794 RWTQ
#11 |
I'm hoping to make 560+ with my mods. Hopefully I wont get too depressed lol ...
p.s. I'm trying to aim low and be surprised lol |
#12 | |
Drives: Anything I want Join Date: Oct 2008
http://www.camaro5.com/forums/showthread.php?t=404200 Last edited by ADM PERFORMANCE; 08-20-2016 at 11:26 AM. |
#13 |
Forgot about that one! 650 RWHP!
-Don
747 RWHP 794 RWTQ
#14 |
9.1 lower, 2.5 upper, and E85.
