AEROMOTIVE A1000 STEALTH KIT FUEL PUMP GREAT PRICE W/JUICED MOTORSPORTS
Similar to the successful Corvette Stealth System, the new Camaro System is a complete drop-in single fuel pump assembly for 2010 and later Camaros. The system provides a single A1000 or Eliminator Fuel Pump capable of supporting big HP. The best part, it drops right into your factory tank. It still incorporates the factory jet siphon system, includes an integral 100-micron pre-pump filter and an ORB-08 return line port. Now with a true return-style system in your Camaro, you can support the power your making without the worry of the siphon system and while maintaining your factory fuel tank. All while saving you money! PRODUCT FEATURES: Fits 2010 (5th gen) and later Camaros
ORB-08 outlet and return port Incorporates factory jet siphon system and sending unit Includes an integrated 100-Micron Stainless Steel pre-pump filter Utilizes the factory tank, o-ring, lock ring and mounting location Includes everything necessary to install the pump into your tank. Requires the use of a bypass style regulator and return line. 18673 – A1000 Camaro Stealth Kit Supports up to 1300 HP ‘ naturally aspirated Supports up to 1000HP forced induction ![]() AEROMOTIVE A1000 -18673 |
Great pump set up
Big power needs big power.
BIG POWER NEEDS BIG TIME FUEL
Huge boost needs big fuel upgrades.
#6 |
Big power needs big fuel
#7 |
Great pump
#8 |
When you need big power you'll need big fuel
#9 |
![]() Drives: 2018 ZL1 Garnet Metallic A10 Join Date: Feb 2016
Does this pump require the installation of all new lines, or does it use factory plumbing?
Buck
"I don't anymore, but I ustacould!" 2018 ZL1 Garnet Metallic |
#10 |
PM sent, yes, it will require a return line. We do have plug and play options available.
#11 |
You can't make serious power with out a big pump
#12 |
Great pump for big power.
#13 |
great pump
#14 |
Big boost needs big power
| Tags |
| 18673, a1000, aeromotive fuel pump |
