Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 08-16-2016, 10:40 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
SQUASH PERFORMANCE DUAL FUEL PUMP SYSTEMS - BEST PRICE WITH JUICED!!!
This is the highest flowing fuel system available for the 2010+ Camaro for both gasoline and E85. This dual fuel pump hanger is built from CNC machined 6061 aluminum and is completely sealed using o-ring construction. Nothing but the best components are used throughout.
The unit is built to use the Camaro's bucket "shell" to minimize the effects of fuel slosh. They are furnished with this part already installed so you don't have any extra down time.
Includes your choice of -8 and -6 AN fittings. The ports are both machined for -8 o-ring type fittings.
Our plug and play return-style wiring harness has double 10ga wiring, circuit breakers with mounting bracket, socketed relays, and plugs into the stock vehicle harness in place of the stock fuel pump.
A Hobbs pressure switch with 15' pigtail and sealed connector is used to fire up the 2nd pump at 1-2 psi of boost.
Some additional features:
Heavy duty sealed connectors
Pumps wired individually so you can power one pump using a Hobbs switch
Anodized for corrosion protection
Stainless steel hardware
Viton o-rings
SQUASH DUAL PUMP KIT
Juiced1 is offline   Reply With Quote
Old 08-30-2016, 09:22 AM   #2
Juiced1
Your fueling solution for big power
Old 09-10-2016, 09:32 AM   #3
Juiced1
You can't make big power without a big fuel system.
Old 09-22-2016, 09:07 AM   #4
Juiced1
Great fueling option
Old 10-05-2016, 10:14 AM   #5
Juiced1
Great fueling options
Old 10-18-2016, 12:55 PM   #6
Juiced1
Huge power capabilities
Old 10-31-2016, 09:37 AM   #7
Juiced1
Great fueling system
Old 11-15-2016, 09:13 AM   #8
Juiced1
Want to run over 1000HP with E85.....No problem
Old 12-08-2016, 11:33 AM   #9
Juiced1
Big power needs big fuel!
Old 12-22-2016, 09:35 AM   #10
Juiced1
Top quality pumps
Old 01-04-2017, 09:15 AM   #11
Juiced1
Huge power capabilities.
Old 01-17-2017, 09:18 AM   #12
Juiced1
Great fuel pump for big power.
Old 01-17-2017, 10:03 AM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Pm price to include all electronics upgrades please. Shipped to 43460
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-30-2017, 12:42 PM   #14
Juiced1
Huge fuel delivery
squash dual pump
