THE U
Drives: Camaro 1SS/RS Join Date: Jul 2015
Help: front brake pad suggestions
Going to a 17x5 Weld front set-up and thinking of replacing the front brake pads instead of cutting off the roller skates. Any suggestions on which pads to run?
Thanks.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I'm on my second set of Autozone Gold series as of yesterday. 107K miles on my car. 65K on the first set.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Too much is never enough!
I like the Hawk HPS pads, they don't have the initial bite that the stock pads have, but they don't fade as much. I don't know how you intend on driving your car, so I really can't recommend anything other than what I have experience with.
Drives: 2010 2SS/RS Join Date: Jun 2009
Hps were good when I had them as well
THE U
Thanks, cars a daily with 2-3 trips to the drag strip a month. I drive pretty aggressive though. Just want to eliminate the roller skates. Don't mind squeaking or brake dust.
#6 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I just did a set of Duralast? pads from Autozone on my car last weekend. So far they are good.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#7 |
![]() ![]() Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
I've always like centric posi quiet and akebono ceramics
#8 |
I am running the EBC "Red Stuff" pads right now. They are a substantial improvement over the original pad. I haven't had them long enough to get an indication of wear but the really lock down the heavy camaro quick. Impressive so far.
| Tags |
| drag, pads, weld |
