Old 08-19-2016, 09:50 PM   #1
Dwright
Drives: 2011 Camaro 2ss
Blown motor after lsa and tune
So this week has sucked. The tuner showed up to tune my car after an lsa install
30 minutes after leaving I dropped a valve and tore the hell at of the # 8 cylinder. Just ordered a new 408 ci striker block from tsp. I hope this I can get more than 50k miles on this block. I am not blaming the time or tuner but the car hit 8,000 rpm between 3-4 gear. Then 10 miles later it was done. I just don't want this to happen with the 408 ci block.
Dwright is offline   Reply With Quote
Old 08-19-2016, 10:06 PM   #2
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
8K.......was there no limiter set??
Holy crap man that sucks
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 08-19-2016, 10:18 PM   #3
Dwright
I had the car towed back up to the shop before the tuner left town and he said it wasn't possible that the rev limiter was set at 6200 rpm. So idk, I am not blaming him, I know what I saw on the gauge I am just nervous now about the same thing happening on the new block. I had one shop install the cam and heads and wasn't happy with there work so had another shop do the lsa blower, e85 flex fuel and the carbon fiber drive shaft. They believe it goes back to the cam install, again not blaming anyone but really blew my weekend plans to hell.
Old 08-19-2016, 10:23 PM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I'd go to a new tuner next time....
One with a real shop and a dyno. I'm sure there are plenty of reputable shops near you.
Members will chime in with suggestions soon I'm sure.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 08-19-2016, 10:55 PM   #5
cc-rider
Drives: 2010 Camaro SS
Or learn to tune yourself. Best thing I ever did. It takes a lot of reading and time studying until you get it...but it's worth it and you realize how long it takes to get it nailed perfect.
cc-rider is offline   Reply With Quote
Old 08-19-2016, 11:02 PM   #6
Dwright
I have started to learn it, but need a lot more time to get it where I would feel comfortable tuning a car I have this much in. The 408 ci block should be a fun build. But I don't think I will be ready to tune it myself by the time it's done.
Old 08-19-2016, 11:37 PM   #7
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Sucks to hear that but I've been through this already. When my 6l80 gave up it lost a gear and the rpms went really high. Probably 8k too. Put in a th400 but the motor wasn't ever the same. Now my motor blew 5 and 7 cylinder. After a long wait it finally shipped. A forged 376. Hopefully it'll all be worth it. Hang in there
camarosspower is offline   Reply With Quote
Old 08-20-2016, 02:26 AM   #8
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
WOW you ordered a stroker from TSP. WHY? There are WAY better options
What is so special about this engine?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 08-20-2016, 01:04 PM   #9
Dwright
Nothing special about the block. It was between the 408 ci, 418, or the 427.
The 427 was a little bit more than I wanted to spend. The 418 wouldn't hold as much
boost/max hp for what I was told. So the 408 was the best choice for the set up I already have. Nothing really special about any block, but it should be a hole lot stronger than the ls3 stock block. What would you have went with? I have dealt with tsp in the past and they offer great support. Every 408 ci block I looked at and priced was with $600.00 of each other
Old 08-20-2016, 01:14 PM   #10
Dwright
Yeah it sucks but you have to pay to play. I only know of one tuner in nc/sc which is pcm of nc but they are always 3 months out from being able to tune it
Old 08-20-2016, 03:17 PM   #11
LSX Camaro
LSX Camaro's Avatar
ERL Performance the only one I would run. There are tremendous differences between blocks, how they are machined, sleeved and the material they are made from.
Old 08-20-2016, 03:36 PM   #12
Dwright
I will admit they have some nice blocks but their 408 ci says it's rated for 600 hp moderate. With everything going on the new block I will be well over that at the wheels. It maybe I am miss reading the rating. It is the same price however I paid for the tsp iron block
Old 08-20-2016, 05:01 PM   #13
camarosspower
I got mine from sdpc.
Old 08-20-2016, 09:58 PM   #14
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
+1
Sucks to hear... Good luck on the next build.
RealQuick is offline   Reply With Quote
