08-22-2016, 10:21 AM | #1 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Anyway to adjust picture size on the forum?
When large pictures are posted, it shrinks the other posts to a very small size so the picture will fit on the screen or the picture must be scrolled sideways to see it all. Is there a setting I can use that makes all posts the same size and or shrinks large pictures so the posts are easier to read?
08-22-2016, 08:16 PM | #2 |
Drives: the 2nd amendment home Join Date: May 2008
In USER CP/EDIT OPTIONS toward the bottom of the page there is an option to specify how large an image will size, but I've never used it before..... I'm gonna play with it, I'll let ya know.
[edit] it looks like it works with linked images, but not with attached images. I set it to 200 max, and the linked images are a bit larger than a thumbnail after fully loading, but attached images stay original size.
-- Benjamin Franklin |
08-22-2016, 08:17 PM | #3 |
Camaro: A Legend Reborn!!
What I do in this case is hold control and press the "-" key and it zooms it out so you can see it all without scrolling back and forth. It basically zooms out your viewing screen, then press the "+" to zoom back in.
[SIGPIC][/SIGPIC] |
08-24-2016, 02:10 PM | #4 |
I use my phone primarily to view the forum, and it shrinks all posts down until the pictures fit in the screen of the phone, which is nice to look at pictures but it makes posts so tiny I have to blow it up to read. More of an annoyance than anything really. I was just hoping there was a way to set it so that all posts (with or without) pictures stayed the same size.
08-24-2016, 02:13 PM | #5 | |
