![]() Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
E85 - 1st fill up
filled up @ $1.69 gallon .... going to do some data logs with Will and see how everything looks over next few fill ups .... seems to be pretty much an even trade off from cost to mpg...
already on it!!
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Subscribed!
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Updates? That thing has to be screaming by now
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 1LS Red V6 Join Date: Aug 2015
AHH! This is going to be insane. Will and I were just talking about this.
And now I need cams.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
#6 |
Can you add me to the cams list?
#7 |
she's feelin good - filling up again Friday and the running logs..
#8 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
#9 |
![]() Drives: 2017 ZL1 A10 Join Date: Sep 2014
This site has so many teasers
Current: 2017 ZL1 A10 previous: 2019 1SS A10 previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears. Past: '12 LFX, full bolt ons + E85, 302hp/267tq |
#10 |
9 Year USMC Vet
Drives: 2014 1LT black on black Join Date: Nov 2015
How did the cams run you and how much gain did you see?
A lot of stuff done so far to make it look better and be more fun to drive.....
#11 |
Yeah not worth it in my opinion. So many better modifications for 1K
Instagram @orange_maro_
#12 |
![]() Drives: 2015 Dodge Challenger R/T Scat Pack Join Date: May 2016
Sub'd
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein |
#13 |
![]() Drives: 2017 1SS Camaro Join Date: Jul 2016
Does will have some type of base tunes for the mace cams that can be ordered online? or would I have to take it to a dyno and tune for them that way?
#14 |
hi - Will can tune them in fine... did better than my dyno tune!!
