Old 08-23-2016, 07:07 AM   #1
derek1387
Drives: 2015 1LS Red V6
The Build Thread: KPE Powered LFX Camaro
Well, its time to start the build thread
As many of you know, I am working with KPE on developing a new and improved supercharger kit for the LFX platform, and then branch back to the LLT. KPE has bought out the rights to IPF's kit, and made many improvements to the kit, and are bringing in some upgraded parts and tuning in the package. I do NOT know the pricing that it will be at, but Jay and Ryan will be tagging along on this post and other posts, with whatever information you want.
The plan is to do a full DIY install thread, with dyno numbers for a VMAX TB, and 80MM TB, as well as with the stock 3.8" pulley, and a 3.48" pulley.
So, to preface...
2015 1LS Camaro Red Hot LFX with 13120 miles
Catless downpipes, NPP Dual Mode exhaust with Magnaflow 11386 X pipe
Jacfab ported manifold and spacer
Overkill Tuning, 80mm TB, E85 kit
bunch of suspension work....check out the other threads.
This is the Supercharger thread!
Key upgrades to the KPE kit over the original kit
Blow through 3.5" MAF with flow straightening screen. Allows for far better efficiency and tuning ability.
Improved pulley and bearing design. More robust for trouble free operation for years to come.
Larger, more efficient intercooler. The cooler the air charge, the more power. We do NOT paint these either as the paint reduces heat transfer.
Relocation and redesigned power steering reservoir and adapter. Moves reservoir up and back for ease of access and no kinking of hoses, Better flow to the pump from reservoir.
Addition of proper crankcase evacuation system specifically designed to provide constant crankcase evacuation avoiding oil contamination and extends engine life.
Special machined in anti-slip texture for improved grip.
Will Overkill tuning. Will is one of the most talented tuners of the GM GDI engines allowing more power, better efficiency.
Larger 6203 bearing that is standard for most OEM idler/tensioners and in many V8 big boost centri kits.
Parts show up today via UPS in the afternoon. So I will post pictures then of the parts
As for right now....
yesterday I installed the Denso ITV22 spark plugs that come highly recommended by MagnumForceGB
Also installed a 2 bar MAP sensor from the ATS 2.0T engine. Direct fit, just need to trim the intake manifold a hair. This MAP will work perfect for the supercharger build. Its part number is AC Delco 12643955. It was $24 on Amazon. Just need to change the linear and offset numbers in the tune. Will knows this, but if you do the install on your own, and do your own tuning, the numbers are 424.99 and -32.50
As for my boost gauge setup, it also has a wideband built in. It is the Innovate PSB-1. I did not do an install write up on it, but certainly can if anyone needs help!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 08-23-2016, 07:08 AM   #2
derek1387
Starting off by getting the car up on jack stands in the front-Not needed, but gives better access to everything. You will need to remove the front fascia and wheel well liners (not needed, but, again, easier access). If you have a catch can system (YOU BETTER HAVE!) go ahead and remove that now. Also feel free to remove your intake system, as it will need to be out of the way.
To remove the front fascia, you will need a 7mm socket, 10mm socket, flat head screwdriver or pick (for the push lock connectors), and a T15 torx bit
You will have 5 total T15 bolts in each wheel well liner, and 3 7mm bolts on the bottom of the liner.
Then 7 10mm bolts to remove, and 2 7mm bolts, and 5 push lock connectors to remove the front fascia. Once you remove the front fascia and wheel well liners, put them somewhere safe, as you don’t want to have to re-paint!
BTW, all photos are shot with a Nikon D5200, or my iPhone 6+.
Parts show up today…so unboxing, and…hopefully pre-assembly later on!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 07:09 AM   #3
derek1387
Reserved
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 07:10 AM   #4
derek1387
Reserved 2
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 07:11 AM   #5
derek1387
Reserved 3
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 09:12 AM   #6
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Let's do this man!!
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 08-23-2016, 09:19 AM   #7
Shawno72
Shawno72's Avatar
Also nows the perfect time to upgrade the Z/28 grille. Just saying
Old 08-23-2016, 09:33 AM   #8
derek1387
Originally Posted by BooSTedFoST View Post
When did you do the SS hood and ZL1 rock guards?!?!
I cut the hole for the SS heat extractor about a week ago, and did the ZL1 diffuser and rock guards a month or two ago
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 02:01 PM   #9
darcycook
darcycook's Avatar
Drives: 2013 v6 auto 1LT
whats the info on the spark plugs , better spark ect? im a daily driver be a good upgrade?
darcycook is offline   Reply With Quote
Old 08-23-2016, 02:09 PM   #10
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Ahhh chock those rear wheels! What's wrong with you You can't let Lola get hurt.
Excited to see the build finally happening. Good luck with everything!
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-23-2016, 02:21 PM   #11
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Looking good, hood turned out nice too.
Please tell me you have chocks on those rear wheels.
Lola is way to pretty for some idiot to come along and knock it off the stands.
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 08-23-2016, 03:42 PM   #12
derek1387
Chocks are in place, and E Brake is on
And parts are here!
Sneak peak till this evening
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 03:49 PM   #13
derek1387
3" thick
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-23-2016, 05:16 PM   #14
shags
shags's Avatar
Drives: 2016 SS Garnet Red A8
who's installing it the KPE shop ?
shags is offline   Reply With Quote
