Old 08-26-2016, 03:11 AM   #1
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
Max size Wheel/Tire Combo (width)?
Hello, I'm a longtime member but a new 5th gen owner. I've got a 2013 Camaro SS and I'm wondering whats the max width wheel/tire combo that my 5th gen can use without any modifications. I couldn't find a direct answer to my question searching, but I'm hoping someone can help. I've seen people on the forum with 315's out back, and I'm curious to know if thats without any modification. Thanks everyone.
Also I plan on getting the MRR M228 rims Im just worried that a 10.5"-11" wheel wont fit
TFord is offline   Reply With Quote
Old 08-26-2016, 04:51 AM   #2
Coors9
Coors9's Avatar
Drives: 2011 Cyber Gray 2SS RS
I have 10.5 front and 11.5 rear. Not lowered and no problems.
Coors9 is offline   Reply With Quote
Old 08-26-2016, 08:35 AM   #3
KillboyPowerhead
Drives: 2015 Z/22
Can't say from personal experience but from the many hours of research I've done: 305 can fit in the rear without any modifications as this is the stock size for the ZL1 (+43 mm offset); 315 can fit but regardless of the wheel offsets/suspension mods there is potential for rub (when there is a lot of weight in the back/trunk and you hit a big bump/hole); up front 285 can fit without mods as this is the stock size for the 1LE/ZL1 (+23 mm offset); not sure if 295 can fit without sticking out without mods (namely smaller diameter springs); I believe 305 will stick out regardless, hence the fender flares on the Z28.
Feel free to correct me on any of this as I would like to know this info too!
KillboyPowerhead is offline   Reply With Quote
Old 08-26-2016, 02:21 PM   #4
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
285/35 up front on a 10" wheel
315/35 rear on a 11" wheel
To avoid issues with stabilitrack, it's generally recommended to go 275/40 front (10")and 315/35 rear (11").
Just chat with Paul at Need4Speed, he will hook you up.
JimE is offline   Reply With Quote
Old 08-26-2016, 03:11 PM   #5
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
thanks guys!
Old 08-26-2016, 03:24 PM   #6
SLY5ACE
Drives: 2013 camaro ss 1le supercharged
i run 295/35/20 mpss on front and rear of my car no problems i do have the 1le package with the zl1 rims but it works awesome
SLY5ACE is offline   Reply With Quote
Old 08-26-2016, 06:50 PM   #7
Stroke9
Drives: 2015 AGM 1SS
This ^^^^^
Stroke9 is offline   Reply With Quote
