Old 08-27-2016, 12:58 AM   #1
High Magnitude
High Magnitude's Avatar
Drives: 2014 2LT Camaro
Car left untouched for 19 days. Help???
So I went with my girlfriend to Texas and left my car with her mom. When I come back the car starts shaking like crazy but I figured it's nothing really (stupid) then later that day my car starts getting warnings for no stabilitrak and engine power cut off. Now I'm getting worried because sometimes when I start up my car nothing happens, sometimes the engine light comes on and nothing happens and then sometimes the engine says its cut off power and stabilitrak is disabled and I can't go over 20 usually. My gf says I just need to jump it but I'm scared the battery is broken or something because it seems so random when it goes into low power mode. I really trusted my girlfriends mom to at least turn it on or drive it once a week but it's whatever I guess. I even said she could drive it to work if she wanted but I guess that didn't happen. Anyway I'm sorry for the wall of text. Can someone please give me any advice? I'm praying it's just something small because I can't afford anything big right now. Cheers guys.
Dan
With great power comes with responsibility. However with great horsepower comes a hell of a lot of speeding tickets.
High Magnitude is offline   Reply With Quote
Old 08-27-2016, 01:11 AM   #2
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Not sure about the 'whacking' issue, but if you're having starting problems, go to your local AutoZone or other parts store & have the battery tested. That's where I'd start anyway.... good luck.
Old 08-27-2016, 02:09 AM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
If the car is not having any issues starting I doubt it's the battery. FYI, batteries get discharged not broken.
Anyways, is the check engine light on? Do you have a code reader? Code readers are like 10 bucks on Ebay/Amazon, I suggest you buy one before you spend a bunch of money on a 'diagnostic' from a shop. Or...your local Autozone or Advanced Auto might be able to read the codes for free (if you have codes).
LCPLPunk is offline   Reply With Quote
Old 08-27-2016, 06:40 AM   #4
Ryanbabz71
Ryanbabz71's Avatar
Shaking could also be due to flat spots on the tires. If mine sits it will shake and wobble for a few miles (normally after being parked for a month+
Ryan
Ryan
Old 08-27-2016, 07:57 AM   #5
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
Originally Posted by Welker2 View Post
...have the battery tested...
^^^This^^^
These cars can do bizarre things when the battery is low.
Iron Lung Jimmy is offline   Reply With Quote
Old 08-27-2016, 08:20 AM   #6
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Originally Posted by Iron Lung Jimmy View Post
^^^This^^^
What he said. After 19 days not starting could be a dead cell. Battery strong enough (at times) to start car but not enough volts while running causing REP, Stabilitrak msgs. You'll find other forum posts that have experienced the same problem when batttery was bad.
camguynj is offline   Reply With Quote
Old 08-27-2016, 08:21 AM   #7
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Ummmm... It's a 14 and under warranty. Take it to the dealer and have it checked over, problem solved.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 08-27-2016, 08:26 AM   #8
MrChrisLS3
Drives: 2018 1SS M6
I don't know, 19 days isn't really a long time, so it shouldn't have any of the 'storage' issues. Battery rundown certainly can happen, but it should be recharged by now. What kind of gas was in it when you parked it? Again 19 days isn't a long time, but if it were cheap 87 octane, perhaps it got stale, especially if it's e10, which most is, it may have absorbed moisture. This could cause some spark knock, detonation. Maybe fill it with 91 with some techron additive? Try consulting your service dept since you're still under bumper to bumper.
MrChrisLS3 is offline   Reply With Quote
Old 08-27-2016, 09:19 AM   #9
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
19 days is nothing....mine sits for months in the winter...I try go take it out for a spin a couple of times during the winterand i have zero issues . Like people have said. ...its under warranty . Take it to the dealer .
rontammy0 is offline   Reply With Quote
Old 08-27-2016, 10:34 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
dealer...and a scan.
Old 08-27-2016, 01:33 PM   #11
High Magnitude
So I took it to a shop that I always go to and they have really good prices. They said 80-95 for resetting the codes. Is that good? He said the gas pedal sensors weren't in sync or something. He said it wasn't a warranty issue.
Old 08-27-2016, 01:46 PM   #12
rontammy0
If your car still has full warranty. ...you shouldn't be paying anything. Anything you think may be wrong should be looked at by the dealer until your warranty is up. If the shop plays with something that would be considered a warranty issue by the dealer....they may not honour it. Let the dealer decided what's warranty related and what isn't.
Old 08-27-2016, 01:49 PM   #13
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
What mods have you? VTC?
CamaroFred is offline   Reply With Quote
Old 08-27-2016, 02:21 PM   #14
High Magnitude
Yeah VTC
battery, jump, power, stabilitrack
