Old 08-27-2016, 03:25 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
What happens when the dealership can't fix my Camaro?
I've been going back and forth to the dealer for the last two months with the same issue, I literally dropped it off and picked it up 5 times for the same problem ending with the same result, limp mode and check engine light. The dealer has reached out to GM and had a few different technicians work on it but they can't seem to figure out why it keeps going in limp mode. I'm curious whats the next step, I just got off the phone with the service rep who os gonna call me Monday after he speaks with his boss. He said they don't know whats wrong with the camaro. And all this is after they installed a new block due to a bad oiling issue.
C-redfly is offline   Reply With Quote
Old 08-27-2016, 03:40 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Lemon Law. Look into it. Talk about a buy-back, also.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 08-27-2016, 03:52 PM   #3
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Yep lemon your safety ...talk dealer get regional rep and start the process..this is why you never want get the garage mad because they can accelerate the process.
ssrs2lt is offline   Reply With Quote
Old 08-27-2016, 04:50 PM   #4
Welker2
Ret AF, cancer survivor
Welker2's Avatar
As already stated, lemon law. Several years ago, my sister, who lives in California, bought a new Dodge truck that would die for no reason at any time, to include at freeway speeds. Long story short, after a year of constantly taking it to the dealer & them not finding/fixing the issue she got her full purchase price back plus all taxes, registration & other fees ...good luck resolving the issue
Old 08-27-2016, 06:10 PM   #5
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
Like others said, Lemon Law.
Looks like you might have a small battle in front of you.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 08-27-2016, 06:53 PM   #6
ritchet
ritchet's Avatar
Drives: 2015 Camaro 1LS Red Rock
As others have said, you are in CA and this should qualify as a lemon. As a former Mfg rep for BMW, we would buy the car back after 3 unsuccessful repair attempts.
ritchet is offline   Reply With Quote
Old 08-27-2016, 06:54 PM   #7
C-redfly
C-redfly's Avatar
Ok thanks for all the replies. The garage is definitely on my side. My service reps really appreciates my patience and always trys his best to help me. I am happy to hear Welker2 mention his sister got full purchase price for dodge. I hope my story can end the same. And ritchet, its been 5 trys so far.
Old 08-27-2016, 07:35 PM   #8
Spurshot
Drives: 2014 2SS blue
The Better Business Bureau is where you initiate a "lemon law" action, if you don't want to go thru a personal attorney. Basically, you file a case, an arbitrator contacts you for an interview. They set a date for a hearing where you and the company rep present your cases. The arbitrator has established rules which they follow for the finding. I believe the findings are binding for GM, but not you .
Spurshot is offline   Reply With Quote
Old 08-27-2016, 08:16 PM   #9
Dwright
Drives: 2011 Camaro 2ss
Had the same problem as you. Took my car in 5 times as it kept going into rip. They wouldn't listen when it told them it only happened when I turned left. Finally I bought an throttle body extension, cut the throttle body wiring harness
Wired the new one in and never had the problem again. When ever you would jump on the throttle while turning left it was pulling on the plug at the throttle body. Can't say that will fix your issue but the dealer ships kept trying throttle bodies and flashing the computer and that didn't work at all
Dwright is offline   Reply With Quote
Old 08-28-2016, 09:15 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Being your Camaro is 12 you must have a extended warranty covering the thing? Replacing the block from a oiling issue is so super bad, that means its starved the top end as well and everything from the timing chain on back most likely and just a block is not the best repair. It would with oiling problem have hurt lifters, pistons rings, bores bearings, rockers, pushrods, springs, timing chain, valves, etc etc.....
And engine problems could have hurt the cats, warped the heads, etc..... Sure it may be a gremlin now but can you trust them....Most likely not, and that's why you and all owners should save every scrap of paper and every repair attempt made can contribute to your being able to lemon law the car out if you have too......... And oiling problem to me would have meant new crate engine. Good Luck
Old 08-28-2016, 09:53 AM   #11
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Lemon Law. Brought my wife's car in a few years ago. Check engine light stayed on. Third time I told the mechanic's boss If it comes back again Lemon Law. Just saying to them her car had no more issue. They had to contact another mechanic for help. And it hot fixed.
Ledzepx is offline   Reply With Quote
Old 08-28-2016, 10:08 PM   #12
MrChrisLS3
Drives: 2018 1SS M6
Good point. Just because this dealership doesn't have the solution doesn't mean there isn't one out there. Although, with warranty service, it is their job to find it, not yours. If they're not working hard enough to find it, then lemon it.
MrChrisLS3 is offline   Reply With Quote
Old 08-29-2016, 09:08 AM   #13
ytown87
ytown87's Avatar
Drives: C6 Corvette
Lemon Law
Call GM corporate
Light a match...
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 08-29-2016, 02:43 PM   #14
deweyg63
deweyg63's Avatar
Drives: 2011 2SS/RS 500+ h.p. monster
My sister had the same thing with a Jeep. Bypass the dealership and talk directly to their regions rep
deweyg63 is offline   Reply With Quote
