![]() Drives: 2014 Camaro RS Join Date: Aug 2016
2014 RS package Brake bulb replacement
I have a 2014 V6 RS and my right brake light has gone out. I suspect it's just needing a bulb replaced. I've looked online and this forum, but can't seem to find instructions on how to do this with the RS package. Some instructions I found last night said to turn it counterclockwise, but that didn't seem to work.
Does anybody have instructions on how to remove the bulb socket? What part # bulb is for the brake light? Also, the problem I suspect is that moisture has gotten into the tail light assembly. Any ideas on how to remove/seal that? I'll be looking at this again tonight, so any help is appreciated! Thanks! |
![]() Drives: 2015 2LT/RS BVM Join Date: Mar 2015
If you have a 2014 with the RS, you should have LED taillights, no bulbs. Maybe you can get it fixed / replaced under warranty?
Well, I did manage to figure out how to unplug the tail light, but it's just a wiring harness plug. No bulb to replace. Looks like I may have to replace the whole tail light assembly.
![]() Drives: 2014 2SS/RS Join Date: Jan 2014
Shouldn't the Bumper to Bumper warranty cover this?
Curious as I have a '14 also. Next March my 3 years are up!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
As long as you are under 36,000 miles.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#6 |
Yes. It's covered under warranty. I was thinking it might be a simple bulb replacement, but didn't realize it was all one assembly.
#7 |
Unlikely the whole thing to go out to be honest. Check the fuse or if there is a bad connection.
| Tags |
| 2014, brake light, rs package, tail light |
