![]() Drives: 2011 Chevy Camaro LT V6 Join Date: Feb 2015
New stealth 3.0 throttle controller unbox and install
Unbox and install of the Stealth 3.0 throttle controller in a 2011 Chevy Camaro. https://youtu.be/KQaCZWB94KE
http://www.Stealth-Controller.com http://www.revhigh.com.au Last edited by crash12928; 09-02-2016 at 09:31 AM. Reason: Fixed link |
#2 | |
![]() Drives: 2ss/rs Join Date: Apr 2016
the youtube link seems to be broken but based on the product info it looks like a good deal
#4 | |
![]() Drives: Ly7 Join Date: Dec 2011
I think this is the one ?
thanks for the link but after seeing this...i am more then happy with my VTC. and will not change it out for this
#6 |
Yes that is.the correct video. Sorry ive been busy at work, i just corrected the link.
#7 |
I had the VTC for about 2 years and it works great. The stealth is better in my opinion, instead of SP1-9 you get SP1-11, but the best part is the auto mode. You can set it to Auto and it will change through the SP settings on its own depending on how your currently driving. The stealth also has a anti theft mode for extra security if you chose to use it.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#9 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
i actually just got rid of my vtc with the supercharger its tough to drive with it above 2..so no really worth it.. when i was NA it was awesome huge difference
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
#10 | |
![]() ![]() ![]() ![]() Drives: 2011 2SS Join Date: Mar 2015
Definitely.. I'm used to how my throttle reacts on its current setting with my vtc. I feel like it would be unsafe If the throttle controller was basically deciding how much throttle input to give. That would be like putting a blindfolded person in the passenger seat and telling them to decide how sensitive the throttle should be based off of how I'm driving. If I put it that way it doesn't sound very fun does it.. Not to knock the stealth. I will admit I wouldn't mind having two more settings. I'm happy with my vtc though
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
#11 | |
#12 |
Been using the 3.0 for over a month now, the Auto IQ is not dangerous at all. It reacts to driver input, you smash your foot to the floor and it will put you on a higher sport setting, cruising around town, it adjusts down to fuel saving setting.
If you want to complain about dangerous, then I hope you never use SP9 on the VTC. |
#13 | |
Never gone higher than 7
2011 SS L99
#14 |
Auto iq is also great for drag racing. As it helps prevent wheel spin on take off. If you like your VTC, that's great, but keep an open mind.
| Tags |
| revhigh, sp5, stealth, stealth 3.0, throttle controller |
