Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 09-03-2016, 02:30 PM   #1
BlakeSS
Drives: 2012 2SS/RS Inferno Orange
Huron Speed Turbo Kit For Sale
(SOLD) For sale is a Huron Speed Turbo Kit. Kit is barely used. Installed it, had it dyno tuned and have driven it about 300 miles. Decided to go the supercharger route. Kit was just over $4600 new selling it for $3500. The details on the kit are as follows:
Full Huron Speed Kit
Not Ceramic Coated, Chrome Cold Side
Kit completely wrapped in DEI Titanium Hear Wrap
Comp Billet 7475 Ceramic Triple Ball Bearing
1.15 A/R housing
Turbosmart Hyper-gate 45 wastegate
XS-Power 50mm Blow-off Valve
Grimm-Speed Manual Boost Controller
Stainless Steel braided oil feed and return lines
Vacuum lines and fittings
2 extra rolls of heat wrap
Extra turbine blanket
LSA Supercharged, 2.50 upper pulley, 3.91 Chevy Performance gears, custom grind BTR CAM, BMR rear suspension, Doug Thorley LT Tri-Y headers, CAT delete, SLP Loudmouth II mufflers, Cold Air Inductions intake, McLeod RXT clutch, Mickey Thompson ET Street SS 305/45/18 raidals
BlakeSS is offline   Reply With Quote
Old 09-05-2016, 11:31 PM   #2
Bambinov8
Banned
Drives: 2015 1le camaro
Thought this kit new was 3700 $?
Bambinov8 is offline   Reply With Quote
Old 09-05-2016, 11:36 PM   #3
BlakeSS
Build it on their website($4400ish) Grimspeed manual boost controller is $100. All the extra heat wrap and blankets ($150ish).
Sent from my Samsung on Tapatalk
Old 09-05-2016, 11:45 PM   #4
Bambinov8
Banned
Oh OK gotcha!
Old 09-06-2016, 09:17 AM   #5
jeff657756
Drives: 2014 SS 1LE
Was this j.curt's kit that he was selling?
jeff657756 is offline   Reply With Quote
Old 09-06-2016, 09:47 AM   #6
BlakeSS
It is.
Old 09-07-2016, 08:02 PM   #7
BlakeSS
Price drop. $3300
Old 09-09-2016, 07:50 AM   #8
Luvdamud
Drives: 2010 SS
Bump for a pretty good deal. If someone already has injectors, this is a steal at that price. You will need injectors. The Bosch 1000's that Huron sells are a little overkill for that small a turbo but still work well. I have the same setup and after chasing and correcting the plug wire gremlins, it is definitely solid. Next step is installing my Innovate EBC, going to 12lbs and going back on the Dyno. My kit has the same size turbo as above and I am now north of 500 RWHP on 7lbs of boost.
GLWS
Luvdamud is offline   Reply With Quote
Old 09-09-2016, 10:03 AM   #9
BlakeSS
GLWS
Thx
Old 09-13-2016, 09:05 PM   #10
BlakeSS
Price drop $3200
Old 09-20-2016, 01:53 PM   #11
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
I have this wit with a Precision 7675... turbo cam and ported heads.
Running on 7 cylinders I made 573rwhp@ 7psi and 608rwhp on 10psi. I had a plug wire that un-clicked from a plug, and didn't notice until I got home from the dyno. I couldnt figure out why the graph was so choppy.
I am heading back to the dyno on 10/8 with 12psi, meth, and more importantly 8 cylinders. I expect to get close to 700rwhp.
RealQuick is offline   Reply With Quote
Old 09-20-2016, 01:57 PM   #12
RealQuick
See dyno graph... boost is pretty much all in by 3000rpm. Also is one of my heads/cam runs (see how smooth the graph was).
Old 09-24-2016, 12:36 PM   #13
BlakeSS
Still available
Old 09-24-2016, 06:50 PM   #14
Ngreenwell
Drives: 2012 camaro ss
Something is wrong with my comp turbo I think , literally just got the kit back and done from dyno and it starts to smoke really bad after a while of driving and my shop says when it's hot the turbine is loose but when it's not hot it's not loose so idk what's going on
Ngreenwell is offline   Reply With Quote
huron, turbo
