Old 09-07-2016, 11:29 PM   #1
2012OrangeVert
2012OrangeVert's Avatar
Drives: 2012 Orange 2SS/RS Convertible
What 1/4 Mike time did you run when stock or close to?
I am going to take my vert to the track soon , and was just wondering. I know about what they should run compared to what stock coupes run, but wanted to get some real people numbers. I only have a cold air intake and a LS3 catback with a GMPP axle-back so far on it. So I am basically stock.
2012OrangeVert is offline   Reply With Quote
Old 09-08-2016, 02:24 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
There is a whole thread dedicated to this, so much so, they made it a sticky.
http://www.camaro5.com/forums/showthread.php?t=21013
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-08-2016, 08:38 AM   #3
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
It's a little different with verts as most of those times are coupes. How many vert camaros you see at the strip? OP, the few times I've been at the track the best I've done with bolt ons and a tune is a 13.2 with stock tires. You be looking at low 14s is my guess.
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 09-08-2016, 02:06 PM   #4
2012OrangeVert
Thanks. That is why I put it here. It doesn't specify between coupes and verts if I recall correctly. And with the vert a little heavier, I knew times would be different. Plus aren't those the fastest people, not average?I did think they would be a little closer though. Well if the weather is good next Wednesday, I most likely will find out. My old 3rd gen ran a 13.2 and my 5th gen feels just as fast. But the butt dyno has been known to be off calibration. And , what Bolton's were you running at the time?
Old 09-08-2016, 06:01 PM   #5
Cavalo Preto
Cavalo Preto's Avatar
Drives: 2011 ss2 convert
I ran 13.3 with headers intake 3" exhaust with tune on stock tires was putting down 425 whp now with 600 whp ran 12.0 on Micky Thompson street drag radials
Cavalo Preto is offline   Reply With Quote
Old 09-08-2016, 08:33 PM   #6
2012OrangeVert
Cool. But wow it looks like I will be slower than I was thinking. I was thinking I would run a mid 13. I hope next Wednesday is clear, and if I can get off work early enough I will find out.
Old 09-09-2016, 12:04 PM   #7
bsimms89
bsimms89's Avatar
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350
When mine was 100% stock i ran 13.68, haven't taken it to the track since the intake, headers, exhaust, and tune
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned
2017 COPO #23 Black w/ Supercharged LSX350
2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust.
1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear
bsimms89 is offline   Reply With Quote
Old 09-09-2016, 03:44 PM   #8
DOC52
THE U
DOC52's Avatar
Drives: Camaro 1SS/RS
Dang, didn't realize the convertibles were that much slower, but I guess thats the sacrifice for having a car thats more fun
DOC52 is offline   Reply With Quote
Old 09-09-2016, 04:05 PM   #9
2012OrangeVert
Now that is closer along the lines to the times I would expect. I will be happy to run that!
Old 09-10-2016, 03:52 PM   #10
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
You got that right.
SS PANTHER is offline   Reply With Quote
Old 09-10-2016, 05:10 PM   #11
Dameat63
Dameat63's Avatar
Drives: 2014 Camaro SS convertible
I just ran 13.9 at 101 mph 3 straight times in a row. 2 times with the traction control on and 1 time with it off. I have a Solo performance cat back exhaust, a street tune and a Halltech CAI. My car is also an automatic. According to numbers I've seen that's almost right in line with the manual version which has 426hp stock. What can I do to improve this time without breaking my budget?
Dameat63 is offline   Reply With Quote
Old 09-12-2016, 02:46 PM   #12
Angie11
Drives: 2011 ss rs convertable
Mine is a 2010 L99 and the only mods are a CAI and cat back exhaust with automatic trans, Ran 13.8XX all day, no matter launch style, fun but not very fast super consistant with auto so in bracket racing you can run a repeatable number all day long
Have fun!
Angie11 is offline   Reply With Quote
Old 09-14-2016, 10:48 PM   #13
2012OrangeVert
I ran it tonite. Best of13.6. I'm neither happy or sad. Feel like it was just an ok time. Makes me want to put long tubes and a tune on it though, I gotta admit. LOL
