Old 09-18-2016, 11:09 PM   #1
Themarowagon
Drives: Black ss
something wrong with my transmission?
So I traded in my '15 camaro v6 for a 14' ss w/manual. It has around 35k miles into it now. I have this problem when Im driving at low speeds (5-10 mph) in first or second gear while letting of the gas pedal i hear this kinda "clapping" noise like almost if something is loose Idk what could it be. Also I have this problem when shifting from first to 2 gear the stick kinda gets stuck a little. Any idea what could it be?
Themarowagon is offline   Reply With Quote
Old 09-19-2016, 01:15 AM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
That's pretty normal for the SS. Some say it's the trans, I think it's driveline slack. If you are smooth you can avoid it. That is, don't suddenly lift, and if you do, hit the clutch before the lift and pull 2nd.
You can start in 2nd if you don't need all the acceleration 1st has.
And the 1-2 can be a bit notchy, especially when cold.
CamaroFred is offline   Reply With Quote
Old 09-19-2016, 01:58 AM   #3
Bo White
Bo White's Avatar
It's the multi piece driveshaft bouncing clockwise and counterclockwise. They call it a two piece....it's a piece alright....
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
gears, ls3, manual, transmission problem
