ZL1 Super Charger Knock
I own a 2012 Camaro ZL1. I am aware that GM has a service bulletin (#13313) out for 2012-2013 ZL1s in regards to a knock/rattle in the super charger.
My ZL1 has a VERY loud knock, rattle and some sort of squeak (as if a belt was slipping) coming from the super charger. I brought mine to the dealership however they stated that the sounds they hear were normal. I had also provided them a CD with the video of the super charger at idle. (See link) The video clearly shows the rattle/knock throughout however see the time stamps listed below for the most noticable sounds. https://youtu.be/lwIO6d5o8iY?t=45s Can anyone tell me if these horrible sounds are actually normal??? Loudest noises at: 0:47-0:50 1:17-1:19 1:33-1:36 1:53 (Loudest) 2:36 2:48 (Very Loud) |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
You'll have to go to a different dealer, until you get the answer you want. You can go to a Cadillac dealer as well ... A "rattle" is not normal.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
Mine did the same thing, go to another dealer, SC needs to be replaced.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
The super charger was already replaced for this problem. This is the "new" super charger which sounds 10x worse. GM said there are no known instances of a second super charger causing issues.
go take it too a different dealer as soon as you can. That is not normal and should not sound anything like that. Best regards, Kayla L. 801.545.4215 |
#6 |
Thanks. Im going to try and see what another dealer says.
#7 |
![]() Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
#8 |
Few years late but, brought it to a new dealership and they replaced it immediately.
| Tags |
| knocking, supercharger, zl1 |
