Old 09-21-2016, 06:05 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
2010 turbo SS part out
New unused parts :
Hawk HPS front and rear brake pads
Improved racing oil pan baffle (SOLD)
JDP brake duct cooling kit
ACDelco ultraguard gold premium oil filter UPF48R (SOLD)
Goodridge high performance brake lines
Comp Turbo CT43 7675 Cast Wheel Journal Bearing - 1.15 a/r, Oil Only Center, 82/75 turbine wheel paid 2800 ....make an offer. brand new in box never used.
used parts that will be removed:
Zl1 factory reproductions wheels and rubber. (SOLD)
On3 Turbo kit hot side coated and wrapped, turbo blanked, upgraded oil feed lines, vacuum manifold, v bands, moroso oil seperator, catch can and filtered check valve vent
AEM Truboost with solenoid
AEM Air/fuel guage.
A-pillar 2 guage pod
Driveshaft shop 1 piece aluminum driveshaft (SOLD)
Driveshaft shop lvl 4 1000hp axles
Dewitts Oversized radiator
I have a 3" kooks axle back that i got customized to fit the zl1 rear diffuser mod with quad tips.
jdp tow hook black
ID 850cc Injectors
snow stage 2 meth kit with upgraded rear tank and upgraded lines.
thats all i can think of for now that will be removed for sure. heres the car for sale so you can see if theres anything else of interest to you and maybe we can make a deal. or just buy the car. I can get pictures if you request immediately. its too much hassle to upload it all but ill start putting some up tonight. thanks.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 09-21-2016, 06:31 PM   #2
superdrummer38
Drives: Camaro 2SS/RS
Prices on brake duct, axles and kooks with diffuser.
superdrummer38 is offline   Reply With Quote
Old 09-21-2016, 06:57 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
How much for Drive shaft?
Auto or manual
Orange Krush II
Old 09-21-2016, 09:24 PM   #4
FireFitz
Drives: 2011 SS
PM sent
FireFitz is offline   Reply With Quote
Old 09-22-2016, 05:16 PM   #5
Abdul_11
Abdul_11's Avatar
Drives: Camaro SS
How much for the two guages, and the driveshaft? is it manual or auto?
Abdul_11 is offline   Reply With Quote
Old 09-22-2016, 05:39 PM   #6
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
interested in snow kit and id850 s pm me details
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 09-28-2016, 09:46 PM   #7
forklord
forklord's Avatar
Drives: 2010 2SS
bump. everything must go. DONT BE AFRAID TO COUNTEROFFER. im broke. desperate actually. sold the zl1 rims and tires for stockers and 110 just as a example...
Old 09-28-2016, 11:02 PM   #8
washd0403
Drives: 2013 2SS
How much for injectors?
washd0403 is offline   Reply With Quote
Old 09-29-2016, 03:22 AM   #9
Aldowelds
Aldowelds's Avatar
Drives: Turbocharged 408
Price on oil pan baffle?
Aldowelds is offline   Reply With Quote
Old 10-02-2016, 02:26 PM   #10
111Scoundrel
Drives: 2015 Camaro 2015 Silverado
Any pictures of the radiator? How much?
111Scoundrel is offline   Reply With Quote
Old 10-02-2016, 04:49 PM   #11
CARABAS88
CARABAS88's Avatar
Drives: 2011 Camaro 2SS
Price on injectors, snow stage 2 and axles ?
CARABAS88 is offline   Reply With Quote
Old 10-07-2016, 03:05 PM   #12
phat9le
Drives: GMC Yukon XL Denali
TruBoost
You still have the boost controller. If so, what model is the AEM TruBoost? How much you want for it?
phat9le is offline   Reply With Quote
Old 10-09-2016, 02:16 PM   #13
CamaroSS/RS
Drives: 2011 SS/RS
If you still have the brake pads, pm me
CamaroSS/RS is offline   Reply With Quote
Old 10-09-2016, 02:30 PM   #14
xc_SS/RS
Drives: 2010 Camaro SS/RS
Interested in the brake lines! PM'd ya
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
