Old 09-22-2016, 11:56 AM   #1
SoChrisB
SoChrisB's Avatar
Drives: 2012 Camaro 2SS/RS
Weird change in AFR
So in the last week or so my AFR has been reading 10.0 at half throttle to full throttle. Nothing has changed with the car. Any insight would be greatly appreciate. I can't seem to figure out why the change and it kind of freaks me out. I was thinking maybe my AFR gauge needs to recalibrated or maybe the change in the seasons here in NY. Any help would be greatly appreciated.
SoChrisB is offline   Reply With Quote
Old 09-22-2016, 01:45 PM   #2
Unreal
Drives: 2006 Z06
Boost leak, belt slip? Does it read fine all the other times? If so I would be looking for a mechanical change that would cause the car to run rich.
Nick
Corvette Z06 -1200ish rwhp
Old 09-22-2016, 02:05 PM   #3
SoChrisB
SoChrisB's Avatar
Yeah, normal driving it averages 14.7. How could I tell boost leak or belt slip? Sorry never dealt with this before.
Old 09-22-2016, 02:11 PM   #4
Unreal
Drives: 2006 Z06
Pressurize system and look for leaks. Check for belt dust, tensioner adjustment, or worn belt.
Also do a general inspection of all the hoses for cracks/etc. Check the bypass valve for sticking/etc. Has boost level changed? That would be a good indication.
Nick
Old 09-22-2016, 04:52 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Depending on brand, it may be necessary to recalibrate your AFR gauge. Not saying that's your problem, but If it's able to be calibrated, then I would do that for sure.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-22-2016, 04:58 PM   #6
stevieturbo
Drives: it changes
More importantly...is it driving any different ?
If it was really that rich at low loads, it would be driving luck **** all and stink like ****.
What wideband is it ? Does it just read that flat number...ie no changes depending on load/rpm ?
stevieturbo is offline   Reply With Quote
Old 09-22-2016, 06:16 PM   #7
SoChrisB
SoChrisB's Avatar
It's a GlowShift AFR. Don't hate my fiance bought it haha. How would I know If that's the problem ?
Old 09-22-2016, 06:18 PM   #8
SoChrisB
SoChrisB's Avatar
And honestly it's hard to tell if it's running like crap because it's like mind-effing me seeing 10.0. And yes, it read 10.0 on decent acceleration, if I rev it and if I'm wot.
Old 09-22-2016, 08:36 PM   #9
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Cleaned your Maf sensor?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 09-22-2016, 08:39 PM   #10
SoChrisB
SoChrisB's Avatar
Didn't even think of that. I'll do that first.
Old 09-22-2016, 09:17 PM   #11
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Id think the car would run like shit and be stumbling all over itself at a true 10:1 afr part throttle, can you log mpg it would go to shit as well. Im betting its the afr gauge/sensor, glowshift lol
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 09-22-2016, 09:30 PM   #12
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
How old is the afr and how close is it to the engine? (I burned up my Inno MTX-L in less than 30 days). I relocated a new sensor 2 feet further down and bought that expensive @ss insulator for it and no issues since. Lots of good suggestions in other posts. I'd start with re-calibration. I don't think glowshift is all that bad - those bosch sensors are not very robust - there are lots of complaints against them throwing errors.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com
SeaCompiler is offline   Reply With Quote
Old 09-22-2016, 10:11 PM   #13
SoChrisB
SoChrisB's Avatar
It's not running like shit. I'll do a mpg check as you suggest. Might shoot over to new era too and have them take a look. They are only 4miles from my house. Then I would know if my AFR gauge is just shit. Blame the future wife. She wanted the color change feature lol.
Old 09-23-2016, 07:36 AM   #14
stevieturbo
Drives: it changes
I really doubt gloshift is any worse than any of the other cheap gauges out there....regardless of brand name. Widebands are all cheap these days
