Old 09-27-2016, 06:29 PM   #1
MSull16
MSull16's Avatar
Drives: '10 Camaro SS LS3
How do you remove rear deck panel? 2010 SS w/ BA system
Title
MSull16 is offline   Reply With Quote
Old 09-27-2016, 08:11 PM   #2
Leo72793
Drives: 2011 2SS/RS
Originally Posted by rydahog View Post
try this..
that does not a damn thing for the OP. OP here is what you ACTUALLY need
Do not try to short cut this process.
1. Remove the rear seat cushion.
2. Remove the rear seat back
3. Remove the plastic trim rocker panels
4. Remove the rear side trim pieces, be careful the air bags are underneath.
5. Remove the rear side panels (large)
6. From the trunk side, loosen the clips holding the rear parcel tray.
7. Remove the side felt carpeting that wraps around the body
8. Remove the trim buttons that hold the parcel tray and careful work the parcel tray off the body, you may have to get you hand under the plastic to snap it away from the metal body. This is a big pain!
9. This will expose the speakers which now come out easily.
10. Be sure to find speakers that fit the very unique mounting style of the rear body mounting area.
The process will take about 4 hours in and out.
Here is a GUIDE someone wrote to give a visual:
http://www.camaro5.com/forums/showthread.php?t=123352
Enjoy!
Leo72793 is offline   Reply With Quote
