![]() Drives: Inferno Orange 2SS Join Date: Aug 2009
Tire Pressure Monitoring System
Last night I got a low pressure light in my back left tire. So I went to the compressor and filled up all the tires to about 40psi. Then I went to the tire monitor system screen and the gauge still read odd low numbers like 33 36 34 35. And my trusty handheld gauge said 40-41 in all tires. So I clicked the reset button, the horn honked 3 times and scared the hell outta me, then the screen went blank and said "Service Tire Pressure Monitoring System" with a big wrench. Anybody else had this problem?
#2 | |
480 HP 2010 2SS
Without data you are just another person with an opinion.
1100 :10/15/08 3000:3/2609 3300:4/18/09 3400 (broadcast)April 25, 2009 3800 (produced):May 4, 2009 #7470 ![]() 4200 (Shipped): June 1, 2009 5000 (At Dealer) June 9,2009 374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg. |
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int Join Date: Sep 2009
From the owners manual.
Reset the tire learn mode. Each tire will have to have air added or removed until the horn beeps, the horn beeping means that the air pressure sensor has learned that tires pressure. Just did it yesterday, had to read the book. Mike |
Well now when I press the reset button nothing happens. It is just a screen with a car and "--" by each tire.
![]() Drives: 2011 Race Red GT500 w/ SVT Perf Pkg Join Date: Mar 2009
I've got three vehicles with tire pressure sensors. When temperatures drop in the fall, mine will all say low pressure. I will air them up to the correct pressure, but the monitor still shows low pressure until the tire monitor system resets itself after a few miles.
None of the cars has reset just sitting there, immediately after correcting the pressure. I don't know if the system resets because of the the time involved (so many minutes), or after distance (so many miles). But I have never needed to "relearn" the sensors with the computer. I like them, they have found a few slow leaks from an embedded object. I just wish I could program the pressure range for them to work in. |
#6 |
2G1FB1EV7A9100028
Drives: 2010 Jeep Wrangler Hemi Join Date: Mar 2009
Mine's done that like 4 time already, once it was the tire sensor, another time it was the valve stem, and two other times they just reprogrammed them.
# 28 - Victory Red 1LT/RS (SOLD)
#7 |
IM A GURL
Drives: 2010/2SS Join Date: May 2009
u put 40 i only put 35 in
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a 3000, Order acc. by P.R---------- n/a 3100, Order available to sequence- n/a 3300, Order sch. for production--- 21may09 3400, Order broadcast------------ 28may09 3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199) 4000, Available to ship 4200, Shipped--------------------9june09 ITS HERE 18JUNE09 |
#8 |
![]() ![]() Drives: 2010 camaro ss Join Date: May 2009
max is 35psi,i personally air them to 32psi cold and then when the tire heats up im at 35psi,thats how i roll
#9 |
Group Provocateur
Drives: Long Distances Join Date: Jun 2009
...IMO is stupid/annoying. I routinely inspect my tires, manually check the pressure, and add air as needed. Never had a problem with this method. I really don't understand why a Camaro has to have the same features as a Cadillac.
#10 |
Institutionally Insane
Tires should be filled to 36 psi cold and will usually heat up to 40 in summer, 37-38 in rain and 37 after a 20 mile 40 degree day drive. Maybe 34 cold in the summer, but not in the winter. You are killing the treadwear and rolling resistance.
I wouldn't recommend 32 psi cold with these tires, especially this time of year. JMO My tires were topped off a few weeks ago with 1-2 psi each when the temps dropped.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
#11 |
so 36 psi it is? Im just going to take it to the dealership to get the light off my dash and fix whatevers wrong. Not going to play with that system again lol
#12 |
![]() Drives: H.O.COPO Join Date: Apr 2009
As I understand all vehicles will have to have TPMS in the future as mandated by the government, part of the TREAD act of 2000 (Explorer rollovers were a contributor to this)
#13 |
Over inflating your tires will just wear out the middle of the tread first, ride harder, and have less grip than one properly inflated.
I believe the pressure recommendations given on the door post are for "loaded" vehicles. |
#14 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
