Old 09-29-2016, 09:18 AM   #1
camaromaybe
CamaroBaby
Drives: Silver 2010 Camaro 2LT RS
Question Driver side window fuse?
The driver's side window in my 2010 Camaro stopped working this morning. Luckily the window is currently rolled up but pressing the switch seems to do nothing. No sounds or anything, I'm thinking it might be a fuse issue or something wrong with the switch itself but I know virtually nothing about car repair. The passenger side window is still working just fine.
My question is, could this be a fuse issue? I ask because in the diagram in the owner's manual it only shows one fuse for the front power windows. It also indicates a fuse for rear power windows for some reason.
But this lead me to believe that if it were a fuse issue, both windows would stop working if they use the same fuse. Or are there actually 2 fuses, one for the passenger side and another for driver's side and I'm just reading the manual wrong.
I think I can handle changing the fuse myself, changing the switch seems difficult but feasible, changing the motor or assembly no way.
I <3 Made in USA
camaromaybe is offline   Reply With Quote
Old 09-30-2016, 06:27 PM   #2
KROLIS
KROLIS's Avatar
Drives: 2017 2LT/RS & 2013 2LT/RS vert
try this?
http://www.camaro5.com/forums/showthread.php?t=420867
KROLIS is offline   Reply With Quote
fuse, window
