![]() Drives: 57Chevy TrailblazerSS 73Camaro Join Date: Aug 2009
competitive launch mode
Has anyone had luck using the launch control on the M6? When I try to use it, as it says in the manual my engine does not stop at a predetermined RPM. It will actualy go past redline if you let it. The manual says to press the clutch and then press the accellerator to the floor and it will stop at a predetermined RPM. Mine does not. Am I doing something wrong? What RPM should it stop at?
#2 | |
480 HP 2010 2SS
Without data you are just another person with an opinion.
1100 :10/15/08 3000:3/2609 3300:4/18/09 3400 (broadcast)April 25, 2009 3800 (produced):May 4, 2009 #7470 ![]() 4200 (Shipped): June 1, 2009 5000 (At Dealer) June 9,2009 374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
it will work, i'm sure you've done this, but make sure you press the TC button quick twice where you get the second indicator light to come on to engage the comp mode, not just the T/C off light. Put the pedal to the metal (or plastic) with the clutch pressed and it will adjust to around 4K rpm I believe, then let it out when you're ready!
5th Gen Camaros of the Carolinas
SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
Faith Keeper
Drives: 2012 Silverado LTZ, 2010 2SS/RS Join Date: Nov 2008
I posted this same question awhile ago.
The solution is that you aren't being mean enough. You have to kick your pedal to the floor like it is a baby puppy. You don't want to do it because it is so cute and delicate looking, but you have to if you want results. (I don't actually kick puppies so please dont send PETA after me) |
#5 | ||
ZEUSS
#6 |
![]() Drives: 2SS RS Yellow, Raptor, Vrod Join Date: Jul 2009
so did it work? I am having the same issue. I get it in competitive mode and timidly rev well past the 4000rpm mark. I got scared so I let off. Do you truly have to "MASH" it in order to kick the rev limiter to work?
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
#7 |
![]() Drives: 2010 Camaro RS/SS TF Edition Join Date: Sep 2009
it works, but I get a lot of wheel hop.
Love it or hate it, my car can transform and kick your cars @$$! |
#8 |
Guys it is really not worth it and it has been blowing out some axles. The test magazine guys said they got to 60MPH faster without using it.
Just think about it: not doing clutch right-BOOM. Trannies and axles have went bang using it. And the dealers are not covering alot of the warranty work when it does break. One member was not coverd because his tires on the rear had to much ware compared to the front and he had to pay for his axle repair. |
#9 | |
![]() ![]() Drives: 2011 GT500 Join Date: Jun 2008
anway, to get launch mode to initiate: - in neutral, on a flat surface (not moving at all) - presss the traction control button twice (you'll see a message on the dic confirming your in comp mode) - floor the gas (nothing gradual, just put it to the floor; the rpms should hold around 4700 or so) - put the clutch in - shift into first - release the clutch - go weeeeeeeeeeeeeeeeeeeee ---- the problem with launch control is that people dont understand how it actually works. the system attempts to monitor what sort of surface your car is currently sitting on within the first few milliseconds of the launch. if your on cold tires, on a cold road you'll have very little grip and the launch will suck (the system does notice this; and will not put as much power to the wheels as possible ie a bad launch). now, if you warm up your tires, and your on something remotely sticky; you'll see amazing times and consistant at that. (there's a reason why on the vette, the launch control does .1 seconds after in the 0-60 then factory spec; but then again they do it right.) in the end, no matter how good you are at launching; a computer will always be better (under the right conditions). same idea behind a dual clutch transmission, no matter how quickly you can shift; the computer will always shift faster then you. enjoy your launch control! ///edit can someone sticky this so people dont keep posting how to launch? this is the 4th time i've written out the instructions. |
#10 | |
Faith Keeper
YES! MASH IT! If you are timid about it you will just redline it every time. |
#11 |
![]() Drives: 2010 Camaro 2SS RJT Join Date: Jul 2009
LOL, the first few times I tried it I also was too timid. Didn't mash it to the floor quick enough, you get scared because it isn't a natural thing to do. However after getting it to work it's bogus as hell. You can do much better yourself after you learn the car's drive train. After the first little chirp or wheel spin it backs off then chirps a second time, backing off again wayyy to much. Maybe it works better in the Corvette I don't know but in this car it seems like a novelty more than anything useful for drag racing with good launches.
#12 |
*sigh*
people never read posts they should. |
#13 |
Ok....so it does work. I was pushing the accelerator down fast and it didn't work, so I thought something was wrong. So I "Stabbed it" to the floor and that is what it took.
#14 |
Whipped
I do a quick "double tap" on the gas. . . works great when done that way.
| Super Sale on Raptor Shift Lights @ KY SPEED | FRCBobby | Audio / Visual / Electronics/ Gauges / Nav | 44 | 11-25-2011 11:34 AM |
| Competitive Mode | DevilKnightFalcon | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 20 | 11-02-2009 05:51 PM |
| Advise on competitive mode?? | stratman2SSRS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 05-27-2009 10:59 AM |
| COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 80 | 05-02-2009 01:20 PM |
| launch mode | jordan 572 | 5th Gen Camaro SS LS LT General Discussions | 6 | 10-31-2008 07:02 PM |
